Access To Outside Faucet Thru Kitchen - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2012, 08:17 AM   #16
DIY staff
Rewards Points: 7,174
Opening up the bottom of the cabinet will be a quick and easy job if you use a Mulit-Tool---
Harbor Freight has a good one for about $20---A better one is the $40 unit --it has more blades and is a tough tool.
Make the opening plenty big--the plumber is going to need room to solder or turn a wrench---Mike---
Old 01-15-2012, 09:31 AM   #17
Any advice on how to cut the planks? The pipe is apparently located at the far right of the cabinet, about under the upper shelf that is visible on the right?
hermione is offline   Reply With Quote
Old 01-15-2012, 09:44 AM   #18
DIY staff
Do your math and locate the pipe---I'd want an opening from the side of the cabinet--over to about 4" from the center of the faucet---then 12" in from the back of the cabinet--
Put tape on your blade to let you know where 3/4" is so you don't go to deep and hit the pipe.
Those Multi-tools are very easy to control---the blade just wiggles back and fourth---
Simple tool---the blades don't do well with nails--so leave the back and side cuts until last.
That's where you will likely hit nails---Mike----
kitchen faucet sudden stoppage amakarevic Plumbing 4 08-31-2011 10:47 AM
Low water pressure on Kitchen faucet DIY_user Plumbing 3 01-08-2010 12:08 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 02:02 PM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 06:54 PM
