Old 09-10-2012, 12:54 PM   #1
Access cover for hose bib shutoff valve
I'm looking for a cover for my hose bib shutoff valve access hole in the ceiling of my basement that I'm finishing. I know I could just use a return grille, but I was wondering if anyone makes a more elegant solution.
I was thinking a 12x12" plastic panel with a snap on/off flush cover. In a pinch I was thinking I could use a two or three gang multimedia outlet box and then the faceplate would be the cover. Does the IRC or applicable plumbing code specify a size requirement for such access panels?
Thanks!
reblace is offline   Reply With Quote
Old 09-10-2012, 08:44 PM   #2
call me E
TheEplumber's Avatar
They make a panel of plastic. Maybe search Home Depot.
We use them a lot for valves. Should be 10-15 bucks
Old 09-10-2012, 09:10 PM   #3
There sold in the plumbing dept. at any Lowes of HD.
Cut the hole and they just snap in place.
Old 09-10-2012, 09:44 PM   #4
I was thinking about doing the same.
Google "plumbing access panel" to research different variety.
allthumbsdiy is offline   Reply With Quote
Need to move a shutoff valve ccaltacc Plumbing 10 05-19-2011 12:34 AM
Flood Control Valve Removal or Access (Bozy Valve) catfishmk Plumbing 1 02-22-2011 10:57 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Replace a shower valve with no access panel ALfromSTL Plumbing 11 12-12-2008 09:56 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
