Access Code? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2010, 11:45 AM   #1
the Musigician
DangerMouse's Avatar
Access code?
Is this ok? I want to put a large access panel (or maybe a pocket door?) inside the bedroom closet to access my plumbing so when it's time for a new water heater, etc... This will also allow easy access to the back of my panel.
The blue is walls, and there will be drywall or whatever I need between the panel section and the plumbing section.
Anyone see anything wrong with me doing this? The PANEL is outside....
(shown in red)
Thanks!
DM
Old 07-14-2010, 11:54 AM   #2
47_47's Avatar
Rewards Points: 58
Not a pro, but I don't see a need for the partition wall at all. You just have to have your clearances.
47_47 is offline   Reply With Quote
Old 07-14-2010, 12:31 PM   #3
the Musigician
I know, but I'll do it anyways, just because I'm paranoid, and the materials are close to free.... Po)
A double door setup on overhead rollers would be best I think, that way I can easily work on either side, or pop off the doors to install a new WH. I'll also need easy access twice a year as I will be adding an inside valve for the garden hose which is 2' away from the source, so I can close it off for the winter and not worry about freeze.
I already did this at the back of the house for a second hose that also shuts off inside the home in the laundry room. Replacing frozen pipes is not on my list of favorite things to do.......
DM
Old 07-14-2010, 01:06 PM   #4
47_47's Avatar
Rewards Points: 58
DM
Thats not being paranoid , I did the same.
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Add shower to claw foot tub - code considerations? Leah Frances Plumbing 2 02-15-2009 12:55 AM
Code Clarification GoyimPersuasion Electrical 24 01-28-2009 03:44 PM
couple of code questions ponch37300 Electrical 9 01-26-2009 10:45 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
