Acceptable Tub Drain Configuration? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2013, 08:27 PM   #16
Rewards Points: 6
Could you post a pic with the drain assembly positioned in the hole and connected to the waste arm? It might help the visualization.
Dan
djlandkpl is offline   Reply With Quote
Old 03-28-2013, 08:34 PM   #17
Originally Posted by TheEplumber View Post
Is there any way you can put the 45 on the waste arm instead of the 90?
Trap seal defined
Thanks for the image. Regarding the question about 45 on the waste arm, I am unable to do so. I have to use the 90 to gain enough space to center the drain. With the 45 into the U, the water seal is just about 4". Is that acceptable?
netdude is offline   Reply With Quote
Old 03-28-2013, 08:39 PM   #18
Here's pics as requested. Thoughts?
Acceptable Tub Drain Configuration?-imag1179.jpg   Acceptable Tub Drain Configuration?-imag1180.jpg   Acceptable Tub Drain Configuration?-imag1181.jpg
Old 03-28-2013, 09:18 PM   #19
Rewards Points: 6
I'm wondering if you put a 45 on the waste arm and add a section of pipe. Spin the trap so that it would be under the tub shoe. Connect it to the waste arm with 2 angled fittings. Only concern would be slope and maybe vent.
Dan
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 10:11 AM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
