ABS Vs PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2009, 03:30 PM   #1
ABS vs PVC
I'm moving some pipes in a remodeling project. All the of the pipes are ABS. I need a fitting that I can't find from Lowes/Home Depot in ABS so I have to use PVC. Is that ok? The dry fit isn't nearly as tight at the ABS/PVC connection. Should I use all purpose cement at the connection or something else?
MikeyP is offline   Reply With Quote
Old 01-10-2009, 03:47 PM   #2
Registered User
Termite's Avatar
Most cements are not listed for PVC to ABS connections and as a rule you should never do it. I know of one cement that is listed for it, but last time I check connecting the two materials together is against code. You might consider either a threaded connection or a Fernco connector.
Old 01-10-2009, 04:02 PM   #3
Remodeling Contractor
A fernco is the way to go. BUT.. yes you can buy ABS to PVC glue. not all purpose glue.
Old 01-10-2009, 04:31 PM   #4
I found a transition glue ABS to PVC for non-pressure joints. I need it in 2 places. Where the drain & overflow meet the p-trap and at a 90 fitting from the T to sewer. Both joints are tub/shower drains.
Should the joint hold up?
Old 01-10-2009, 07:54 PM   #5
Registered User
Termite's Avatar
It is one of those things that they advise against but if you use the right glue and cleaner you shouldn't have any problems with it. I had no choice but to do it on one connection in my basement and it has held up fine. The glue I used is a light greenish blueish color and was specifically for ABS to PVC connections.
