ABS Versus PVC Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2010, 07:03 AM   #1
ABS versus PVC pipes
which pipe should be used under the basement floor, I'm planning to put a new bathroom in the basement, when I broke the basement floor slap to install the new 'ABS' pipes I bought I find that the existing 4" sewer pipe is PVC, white. can I use a PVC 'Y' fitting to make the connection to the existing pipe and then transition to ABS pipe using a 4" x 3" reducer so that I can continue using the ABS pipes I bought under the slab?
maga2 is offline   Reply With Quote
Old 04-26-2010, 09:22 AM   #2
Check with your local Code office. It may not be permitted to use ABS under the slab. I have never used ABS for this type installation, always PVC.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
