ABS Trap Arm To PVC Or ABS P-Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-29-2012, 02:51 PM   #1
buckybadger's Avatar
Rewards Points: 85
ABS Trap Arm to PVC or ABS P-Trap?
This is for a basic wet bar sink. What would be the best option for the P-Trap with an ABS trap arm? Can I just stay with ABS on the P-Trap and thereby avoid doing a PVC/ABS union? Are ABS P-Traps in residential plumbing typically allowed by code?
buckybadger is offline   Reply With Quote
Old 08-29-2012, 03:55 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Use a slip joint trap and you can use any material that is common in your locality.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
plummen (08-30-2012), TheEplumber (08-29-2012)
Old 08-29-2012, 08:36 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We prefer PVC for undersink even though we plumb the main drains with ABS.
The pvc looks cleaner, and seems to last a little longer. Tubular ABS gets real brittle over time.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 12:37 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
