Old 09-19-2010, 08:10 PM   #1
ABS and proximity to heating duct
I'm redirecting the drain from my kitchen sink and while I'm at it replacing the old steel pipe with 2-inch ABS. The most direct run to the stack will have it running parralel to a heating duct for about 3 feet. Is the a best practice (or code!) for the minimum distance to a heating duct when installing ABS?
Thanks!
Seank is offline   Reply With Quote
Old 09-19-2010, 10:22 PM   #2
call me E
TheEplumber's Avatar
Perhaps not the best practice but ok. Support the plastic pipe at 4ft intervals and every change of direction. Also support the steel pipe to prevent sagging.
