ABS Maximum Distance And Angles? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2012, 12:31 AM   #1
Rewards Points: 248
ABS maximum distance and angles?
We want to build a bathroom on the other side of the house. Is there a maximum distance that a 4" ABS pipe can be extended? The task will involve two 90 degree right angles. Is that too many angles?
jackwashere is offline   Reply With Quote
Old 10-02-2012, 12:39 AM   #2
Rewards Points: 582
if you run out of fall 1/4" per ft rise its too far...picture would help
Old 10-02-2012, 12:39 PM   #3
in most places 3 and 4 inch pipe can run at 1/8 inch per foot pitch. use
45 degree bends to make your turns. for a bathroom you only need 3
inch pipe.
Old 10-02-2012, 02:42 PM   #4
Rewards Points: 248
I read on the internet that for 4" ABS pipe 1/8" per foot is standard. Between the start/finish there is approx. 2 feet height difference.
The distance is approx. 50-60 feet total, with two 90 degree turns. That's about 10 feet - 90 degree turn - 30 feet - 90 degree turn - 10 feet.
Old 10-02-2012, 03:59 PM   #5
at 1/8 inch per foot you would need 7.5 inches in 60 feet. use a 45 and a street 45 to make the 90 degree turns, if you have the room you can put a short piece of pipe between regular 45's. if any are outside corners use a wye and a street 45 and put a clean out in the end of the wye. put a clean out at the end of the run. is this in a crawl or a basement.
Old 10-02-2012, 06:22 PM   #6
Rewards Points: 248
crawl
varies between 2-5 feet of space between the ground and the floor joists
Old 10-02-2012, 09:05 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you read it on the internet it must be true.
1/8" per foot here is only legal outside of the structure which includes porches, overhangs, decks, etc...etc......
Also in regards to change in direction : Horizontal changes of direction in excess of 135* require a cleanout.
First you need to decide whether or not you already have a cleanout, which direction it's intended to service, and how many degrees change of direction are on that line after the cleanout. This will tell you where you will need cleanouts.
At 1/4" per foot you should have plenty of room, assuming that your measurement of 24 inches is from the bottom of the joist to the top of the pipe.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
ben's plumbing (10-02-2012), ddawg16 (10-02-2012)
Old 10-02-2012, 11:30 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 818
Where did the 1/8" come from....I have never heard that.....maybe it applies to drainage for a yard.....
ddawg16 is online now   Reply With Quote
Old 10-02-2012, 11:34 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 350
UPC- 4" may be ran at 1/8"ft, fixture load is decreased by 20% and is subject to AHJ approval. Inside or outside. It is usually excepted and pretty standard practice in my area when grade is an issue
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (10-03-2012)
