Old 03-23-2009, 12:10 PM   #1
ABS drain leaks
I just installed a washing machine hookup and drain at my girlfriend's apartment.
All went well with the water hookups, t-ing off the copper lines.
For the drain, I wound up redoing the drain under the sink with a Y and T and connecting the washing machine drain through the wall just past the sink trap. This was my only option as it was the only exposed drain to work with, and everything else was cast iron.
First I had a leak in the middle (where I had connected the two drains at the very end), wound up chopping it out and redoing it, then somehow by fixing that I must've cracked a threaded bit at the end. I chopped out the end, put on a new piece (this time without cranking it down with a wrench, but I did use lots of pipe dope), and now that leaks again.
To redo this means literally ripping everything out to the pipe above the sink trap and redoing it all, because there is virtually no exposed pipe to work with, just glued fittings.
It's a 1.5" female threaded bit that goes onto male threads that are reduced from a larger cast iron pipe I don't want to mess with.
Anyway, the leak is so small that I may just leave it it, or goop it or something.
Is this the kind of leak that eventually will clog itself? Or will it get worse? Should I redo it?
Thanks.
wombosi is offline   Reply With Quote
Old 03-23-2009, 12:41 PM   #2
47_47's Avatar
ABS drain leaks
I've never seen a leak fix itself. I'd redo it.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 03-23-2009, 02:13 PM   #3
ABS drain leaks
Any time I see the terms "chop" or "goop" used in relation to plumbing repairs
it makes me cringe. Time to call your local pro.
porchmonkey is offline   Reply With Quote
Old 03-23-2009, 02:55 PM   #4
ABS drain leaks
"chop" or "goop" are technical terms for "it's going to cost twice as much".
hayewe farm is offline   Reply With Quote
Frozen Garage Floor Drain Dragon General Discussion 8 01-25-2009 07:07 AM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
