Abs To Cast - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2012, 10:48 PM   #1
abs to cast
I have a 3 inch cast iron y fitting coming out of my basement floor. the top of the y has a clean out. the opening measures 2 7/8 " I want to add another 1 1/2" drain line to this. My initial plan was to get an abs male threaded coupling, attach it, add another y fitting with clean out ontop. Problem is...a 3 inch abs male coupling is to large to thread into this cast iron.
Any ideas? would copper/brass fitting work due to the thinner material?
Thanks,
Josh
merrill_5 is offline   Reply With Quote
Old 06-23-2012, 03:26 AM   #2
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
abs to cast
i believe it's 2 1/2 you might want to take the c/o cap w/you to plumbing supply dealer don't know where your at, like a Ferguson,Cal steam i do not think you'll find it at H/D or LWS . Maybe a schedule 80 male adaptor
wctekkk is offline   Reply With Quote
Old 06-23-2012, 11:04 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 554
Thanks,
Josh
You need to remove the CO fitting and use a rubber doughnut (tyseal gasket) to attach a new wye and clean out. You won't find a male adapter to fit your clean out
The Following User Says Thank You to TheEplumber For This Useful Post:
VIPlumber (06-23-2012)
Old 06-23-2012, 12:24 PM   #4
Rewards Points: 626
Buy a hub-less connector they are black flexible rubber and you tighten them with the hose clamps that come with them very easy and cheap.
Nailbags is offline   Reply With Quote
Tags
abs , cast iron , copper , drain , plumbing
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
Concrete: Top Cast vs. Acid Stain/Wash sportinwla Landscaping & Lawn Care 0 07-09-2010 02:15 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
