Above Ground Pool - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2009, 06:04 PM   #1
above ground pool
can i pour concrete at the bottom of the outside wall in an aboveground pool
eliel is offline   Reply With Quote
Old 07-16-2009, 06:22 AM   #2
Depends on what the pool is made of, concrete is highly alkaline and is hard on aluminum and steel.
Old 07-16-2009, 08:56 AM   #3
I would not advise it. I have had 3 above ground pools and stone was used around the edges for preventing grass and weeds, and drainage for splashed water. I also used roofing material under the sand base and extended it out at least one foot past the pool edge. This was after the first pool had a large hard weed grow from outside the edge and into the liner.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Grounding an above ground pool wcolon Electrical 18 09-02-2009 02:25 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Replacing cord on a 1.5 hp above ground pool pump LeeAmes Electrical 23 04-20-2009 01:45 PM
Slab Ground pool inspection alexromu Electrical 6 08-06-2008 07:01 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
