About To Start A Bathroom Redo... Questions About Toilet Flange. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2013, 09:47 AM   #1
Rewards Points: 230
About to start a bathroom redo... questions about toilet flange.
Hi everyone,
I'm about to begin redoing my downstairs powder room and I have some questions about the toilet flange. The house is built on a slab foundation and the bathroom currently has linoleum flooring installed in the powder room. I will be removing the linoleum and installing ceramic tiles.
Will I have to remove the flange and install a new one? The reason I ask is becuase I've read that the flange should sit on top of the new tile, as opposed to tiling around the flange. Also, the new floor will be thicker than the existing linoleum, so I'm assuming I'd have to redo the flange in order to bring the flange up to the height of the new floor.
Thanks,
Kevin
Ler0y Jenkins is offline   Reply With Quote
Old 03-18-2013, 10:01 AM   #2
Rewards Points: 27
Kevin,
I'm not a professional so please do wait for them to chime in. I've never heard of having to remove and reinstall the flange when you are installing new flooring, but you are correct that the increased thickness of the tile may reduce the amount of travel you have for the compression of the wax seal on the bottom of the toilet. It is my understanding that you can get a toilet flange extender kit that will bring it up above floor level so you can get the compression you need.
GerardW is offline   Reply With Quote
Old 03-18-2013, 10:03 AM   #3
Rewards Points: 2,516
There is a never ending debate over this question.
Flange on top of finished floor(1) or flange even with finished floor(2).
About to start a bathroom redo... questions about toilet flange.-closet-20flange-flush-20or-20not.jpg
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
jaydevries (03-18-2013), TheEplumber (03-18-2013)
Old 03-18-2013, 10:04 AM   #4
Rewards Points: 13,450
No need to remove the flange.
They make double thickness wax rings just for this.
Old 03-18-2013, 11:45 AM   #5
Rewards Points: 230
Guys,
Thanks for the responses. I've seen the online debate concerning this issue. It seems that as long as the flange is at least as tall (or taller) than the height of the new floor, I should be good. If the flange ends up below the surface of the floor, I may consider getting an extender or redoing the flange.
Kevin
Old 03-18-2013, 01:48 PM   #6
Rewards Points: 87
I just did this exact same thing. Ripped up vinyl (in the powder room no less) and replaced it with porcelain. I did not replace the flange and tiled around it. I used a larger wax ring and it sealed up just fine.
My porcelain is thicker than the vinyl was as well. Provided you get the right wax ring it shouldnt be a problem.
Like you my flange sits in the foundation so I didnt want to mess with it either.
ssgtjoenunez is offline   Reply With Quote
Old 03-18-2013, 06:45 PM   #7
Rewards Points: 636
if it is a 3 inch drain i always recommend hammerlane's option 2 due to some toilets have a large and long horn on them that will not sit inside some 3 inch flanges. then you have to shim up toilet a 1/4 inch so it does not rock
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-19-2013, 08:26 AM   #8
Rewards Points: 660
Ford vs. Chevy?
Pepsi vs. Coke?
Mary Ann vs. Ginger?
Tastes great vs. Less filling?
What else am I missing?
BTW, Ford, Pepsi, Mrs Howell, I don't drink although some house projects almost drive me to it.
B
Beepster is offline   Reply With Quote
Old 03-19-2013, 09:13 AM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If it's on top of the finished floor, there is a chance that the toilet you choose will not sit properly as the inner part of the china under the toilet will hit the flange, causing a need for the toilet to be shimmed.
Journeyman Plumber
Old 03-19-2013, 07:01 PM   #10
There is also a gasket end flange extender made for your exact purpose it's made of pvc looks just like the ring of your pvc flange with a faker glued to the bottom go to a plumbing supply house and tell them what your doing and you should be all set
joes plumbing is offline   Reply With Quote
Bathroom Remodel - General Questions Huffmeister Kitchen & Bath Remodeling 5 10-27-2012 05:22 PM
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Installing New Toilet Flange in New Bathroom C_J_GO Plumbing 1 09-16-2009 11:50 PM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 11:37 AM
