Old 01-22-2013, 10:29 AM   #16
Trucon01's Avatar
About to re-do toilet % shower pipe
I hate bumping my posts, but I would love to have someone chime in on my issue.
Let me know if you need more information or more pictures!
Thanks,
Jeff
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 01-22-2013, 11:35 AM   #17
call me E
TheEplumber's Avatar
Originally Posted by Trucon01 View Post
Can someone tell me if this will be OK? I'm primarily concerned with the location of the 2 inch vent. Can I put it behind the shower drain as in the picture?
I gave you an illustration of an acceptable venting method for my code- the common vent is positioned to vent both fixtures. Your illustration would not pass my code standards because the vent is laying flat plus it is only venting the toilet. Would it work? I don't know.
Old 01-22-2013, 12:15 PM   #18
Trucon01's Avatar
Sorry, I did see your post, but was curious if a single vent would work, like in the drawing i added. Now I know it wont.
By your drawing, it looks like my materials would be:
QTY
1 4" PVC pipe
1 4" x 2" wye
1 4" x 4" x 2" x 2"
1 2" pipe (I can cut to length)
1 P trap assembly
1 90 degree long sweep
1 closet flange
1 4" furnco (connecting to cast iron)
Does this sound about right?
Also, does the Furnco need to be fully shielded or can it just have 2 straps if its going to be buried?
Old 01-22-2013, 04:17 PM   #19
call me E
I've labeled the fittings for you-
When connecting plastic to cast iron inside the house, I like to use a shielded 4" cast iron x plastic coupling- code in my area. Others use a 4" fernco. Be sure the pipe has the outside scale removed or your seal won't be water tight
Old 01-22-2013, 07:03 PM   #20
Trucon01's Avatar
Thank you!!
Where the pipes have a 4 way intersection, what is that piece called? A 4x4x2x2 sanitary cross?
Old 01-22-2013, 07:14 PM   #21
call me E
Thank you!!
That's not really an intersection- the line going to the shower is higher in elevation then the lower line so it is just drawn over the top.
As I said earlier- the tee for the shower can be rotated 360* - wherever the shower sits
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Can you connect a shower waste pipe to toilet waste? microbar Plumbing 15 05-18-2011 03:59 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
