Old 11-01-2012, 08:31 AM   #1
About to get rid of my sump pump. Is this a good idea?
I have a lake behind my house. I have large drainage ditch (big enough to drive a car through) next to my house that drains into the lake. There is a steep slope going from the side of my house down to the drainage ditch.
Currently, my sump pump takes water from under my house, pumps it up over the land, and back down into the ditch. This seems like a strange thing to do when I could just have a pipe attach to my sump pit under the foundation, then run underground directly to the ditch. No more pump required. Gravity does not fail like pumps do.
The pipe would be at least 16" under ground, so freezing should not be an issue. A cleanout would be installed to give me access incase I ever needed it.
I am not worried about the lake or ditch backing up. It has never happened before, even in the hurricane we just had. I am not in a flood zone.
I would also fill in the sump pit with gravel, then concrete over the top. I can then turn the room into something useful.
This seems like a great idea, but I am not a drainage expert. What do you guys think?
Theoda is offline   Reply With Quote
Old 11-01-2012, 08:38 AM   #2
Super Moderator
Do it----Drain to daylight is every ones dream-----I've only been able to pull that off twice---very few peple have that option--or the energy to dig that much----
Old 11-01-2012, 08:42 AM   #3
No way to tell from here.
If the foundations slab is below grade, how do you figure the waters going to run up hill out of the pit to where it's connected to run to the ditch?
Without a picture it's hard to know.
Old 11-01-2012, 09:09 PM   #4
What is the drop (in inches or feet) between the basement floor level and the surface of the lake?
And the lake has never risen that number of inches or feet?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
oh'mike (11-01-2012)
Old 11-01-2012, 09:28 PM   #5
creeper's Avatar
If your property has the pitch then you will be very happy you did it. The peace of mind alone is worth the expense. Be mindful though over time of growth or leaves and other debris blocking the exit of water at the daylight end. It is surprising how little it takes to stop the flow of water
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
Old 11-01-2012, 09:31 PM   #6
creeper's Avatar
Joe: The idea is the water drains to daylight below the depth of the foundation. The house is on a hill or built up area
A picture will tell you nothing. He needs a scope if its not an obvious fall
Tags
e a
smell from sump pump GEORGIO Plumbing 5 05-11-2012 08:32 AM
Sump Pump questions ks-man Plumbing 11 07-28-2011 07:25 AM
Sump pump runs all the time....help? Chris Leach General Discussion 9 07-14-2011 08:00 PM
2FT water in my basement, Need help finding a good portable sump pump willowgirl Plumbing 9 03-03-2010 11:12 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
