Old 06-02-2009, 06:07 AM   #1
Default About drain system.
What you think, is it correct way how to built drain system in this video?http://www.1001answers.com/index.php...ming&Itemid=11
rodrigos is offline   Reply With Quote
Old 06-02-2009, 05:08 PM   #2
DIY'r
ScottR's Avatar
1) This is not the right forum for advertising web sites.
2) Out of curiosity I watched the video, and though it's not a scheme, it's all in metric and uses guidelines from the country of origin, not US plumbing codes.
3) It doesn't cover entire plumbing systems. Just the slope of a drain pipe: 1cm of slope per meter of length. Doesn't take a video to tell people that.
4) Terrible bandwidth. Unwatchable where I am without significant buffering.
To answer your question: No.
ScottR is offline   Reply With Quote
Old 06-02-2009, 07:51 PM   #3
Go to an advertising web site to do your advertising.
al's sewer is offline   Reply With Quote
Tags
drain, system, video
More On This Topic
Hello! I’m Ross on behalf of expertvillage.com. Let’s talk about consumer camcorders. Camcorders have audio and video outputs on them. This one is hidden under a panel here, pull back, and it says audio/video. Now that is absolutely great. We... Read More »
Hello! I’m Ross on behalf of expertvillage.com. Let’s talk about consumer camcorders. What are the different types of camcorders you can use? This one here is like 3 in 1. This is called digital 8 camcorder. This will use both the 8 mm tape... Read More »
Transferring VHS to Digital
Transferring VHS to Digital by Expert Village
Hello! I’m Ross on behalf of expertvillage.com. Let’s talk about consumer camcorders. If you have home movies that are on VHS tapes what you can do is possibly use your camcorder as a transcoder. All that simply means is that you can take and... Read More »
Hello! I’m Ross on behalf of expertvillage.com. Let’s talk about consumer camcorders. What recording mode should you use? This camera has two recording modes. SP and LP standard play and long play. If you look at your videotapes when you... Read More »
Hello! I’m Ross on behalf of expertvillage.com. Let’s talk about consumer camcorders. What is the record lamp? You can see it, it’s lit up. It’s called the tally light. The consumer camcorders are calling it record light in a lot... Read More »
ouside drain system over flowing help ! @mber @dams Plumbing 8 11-29-2008 01:14 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 09:32 AM
drain system besunmoon Plumbing 5 05-28-2008 01:44 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 05:37 PM
How often to drain my hyrdonic system bwoo HVAC 4 01-01-2007 12:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
