Is This About To Burst? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2013, 01:02 PM   #1
Rewards Points: 12
Is this about to burst?
Hi, Found this on hot water line coming from the the heater tank... does this meas it's got a microscopic leak?
The tank itself is in the attic and it's making all kinds of noises. Was thinking about installing a tankless unit in it's place so will replace this "leakage" as well.
Ticking time bomb? How long can I put it off??
Thanks, dedicated DIY'er
frisbeeguy is offline   Reply With Quote
Old 04-16-2013, 01:27 PM   #2
Rewards Points: 218
As far as a microscopic leak on your hot water line goes, it could be just plain oxidation going on there or someone forgot to wash off excess flux after sweating pipe, which causes that color, it can be cleaned with vinegar and baking soda. It's been addressed on this forum many times. Check out link.
http://www.doityourself.com/stry/how...-pipe-joints#b
As far as your hwh; What's that red tag hanging on the gas line for? What brand is it? How old is it? What kind of noise is it making? (maybe sediment buildup crackling from heating up etc. from not being flushed/cleaned on a regular basis) Thanks.
When you go new with your tankless, is this a project you will be doing yourself, or are you going to hire a pro?
Stay tuned, lets see what the pro's recommend.
jmon is offline   Reply With Quote
Old 04-16-2013, 02:11 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
The world altitude record for a water heater is over 200' form a basement in a 2 story home.
I would question the strange drain on the right side of the heater. Usually, a home inspector doing a pre-sale inspection would note any drain the is not straight (no elbows) and does not end about 6" from the floor with an unthreaded end since future people can do strange things to eliminate the temperature and pressure safety benefits. - You never know the deposits from leakage can do to build up the pressure beyond the strength of an older "cold heater" heater.
Dick
concretemasonry is offline   Reply With Quote
Old 04-16-2013, 02:26 PM   #4
Plumber
Is that water heater inside the home, or is that an outside closet ?
DidIDoThat is offline   Reply With Quote
Old 04-16-2013, 02:32 PM   #5
Okay, not a plumber so I'm gonna ask:
Why is the hot water tank in the attic? If that puppy goes your looking at a massive repair bill. If the tank gets old and fills with sediment then needs replaced it's gonna be a true chore to get it drained and out safely. Sorry, this idea just looks bad in my opinion especially when "Murphy's Law" comes into play.
TheJerk is offline   Reply With Quote
Old 04-16-2013, 02:39 PM   #6
Plumber
I missed that the w/h is in the attic.
Being in the attic it should be in a pan and a drain from the pan to outside the house.
Same for the T&P drain line.
Old 04-16-2013, 10:01 PM   #7
Rewards Points: 12
Hey, Thanks for all the replies...
Did someone tell you that you have a ticking time bomb? No, that was my question as far as worrying about the corroded copper. Thanks for link - will do a clean up of it.
What's that red tag hanging on the gas line say? Hmm, I don't know - didn't look at it! I think it's just a Propane Warning tag.
Has an inspector/gas company red tagged this hwh? No
What brand is it? model number? how old is it? Old enough That I want to replace. What kind of noise is it making? (maybe sediment buildup crackling from heating up etc. from not being flushed/cleaned on a regular basis - probably never done) True - Probably not flushed. There is an outside hose bib that's connected though so easy to flush. The noise is "popping" and from the kitchen below, it sounds like a small animal rooting around.
When you go new with your tankless, is this a project you will be doing yourself, or are you going to hire a pro? I put one in my last house w/o a hitch so will do this one as well.
Just a suggestion, attics are not a good place for hwh. Agreed! That's how they all are around here though.
The Following User Says Thank You to frisbeeguy For This Useful Post:
jmon (04-16-2013)
Old 04-16-2013, 10:04 PM   #8
Rewards Points: 12
I would question the strange drain on the right side of the heater. That's just the T & PR valve line. It's piped to the outside.
Old 04-16-2013, 10:05 PM   #9
Rewards Points: 12
Being in the attic it should be in a pan and a drain from the pan to outside the house. It has one.
Same for the T&P drain line.It is also plumbed correctly to the outside..
Old 04-16-2013, 10:18 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 450
Water heaters are put in different places in different areas of the country. If the tank is on a routine maintenance schedule- there's no reason it can't be in the attic.
Your heater sounds like its got a sediment issue. Plan for that tankless soon.
About your pipe- clean it up real good as mentioned. Repost a picture afterwards if you could. It's probably old flux....
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (04-16-2013)
Old 04-16-2013, 10:43 PM   #11
Rewards Points: 218
Frisbeeguy, thanks for answering all the questions. sounds like your on the right track. Hope we helped you out some. Good luck with your project. If you need anymore help or advice, keep asking questions, that's what the guys are here for. Thanks.
My hose valve burst AGAIN! Red Squirrel Plumbing 16 01-25-2013 02:59 PM
My condensor fan capacitor burst! Ned HVAC 5 07-23-2011 09:36 PM
Water heater burst - musty odor in wall! Tiny_J General DIY Discussions 10 02-18-2010 02:27 PM
Burst Coil in Air Handler gruven HVAC 3 09-26-2008 05:58 AM
hot water pipe burst *pics* verena Flooring 7 03-04-2008 09:41 AM
