Is It Abnormal To Have A Sewer Cleanout In A Bedroom Closet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2012, 05:37 PM   #1
Rewards Points: 366
Is it abnormal to have a sewer cleanout in a bedroom closet?
Master bedroom has a bathroom adjacent to the closet and there's a sewer cleanout in the adjacent closet wall.
Acceptable for some conditions, or bad plumbing job?
daluu is offline   Reply With Quote
Old 03-08-2012, 05:50 PM   #2
Rewards Points: 616
on a slab i assume but it could be there for code reasons or a good plumber who thinks i can save someone from digging up thier yard or cutting up concrete to unclog a drain in the future
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-08-2012, 06:00 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 352
Actually it's probably a good plumbing job. Could mean the plumber knew his cleanout code. Or... he expects problems in the future...
If it is not leaking, it's fine.
Take a look around a commercial building sometime, you'll see CO's hidden like Easter eggs.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (03-08-2012)
Old 03-08-2012, 07:06 PM   #4
Rewards Points: 582
good plumbing job...bad would of had cleanout in middle of floor for all to see
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 03-08-2012, 07:41 PM   #5
Rewards Points: 366
Thanks for the info.
Old 03-11-2012, 01:04 PM   #6
Rewards Points: 366
Also forgot to mention, yes the home is on a slab.
Old 03-11-2012, 05:03 PM   #7
Happy to help
Lighting Retro's Avatar
I wish I had one in this exact place right now. The original cleanout of the cast iron pipe has been capped off and rerouted, so there really is no cleanout minus removing a toilet for access. Might be a good reason behind it, but either way, cleanouts are rarely a bad thing when you need one.
Lighting Retro is offline   Reply With Quote
Old 03-11-2012, 06:55 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 984
Do you have an upstairs bathroom, if yes ,,,test tee for inspection.. dual purposes .if no,, clean out at base of the vent thatís offset or re vented, in any case itís not a bad thing. under the IPC we have to put a C/O at the base of the stack.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-12-2012, 10:29 AM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Just curious because I always wonder these things myself : What good do they expect that to do you if that line is filled up to the 2nd floor?
Journeyman Plumber
Dirt in sewer cleanout fatanddumb Plumbing 7 09-20-2011 12:52 AM
Sewer cleanout - which side of trap? Ultrarunner2017 Plumbing 4 08-29-2011 09:56 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 12:10 PM
Cannot locate outside sewer cleanout dkl Plumbing 9 05-28-2010 09:35 PM
Running laminate floor from bedroom into closet bluefitness Flooring 4 05-09-2009 07:53 PM
