Abandoning Drain And Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2012, 01:41 PM   #1
Abandoning drain and supply lines
I am in the process of removing a bar with a sink in my basement.
The ABS drain goes into the floor and has a vent stack that goes up through the ceiling. I believe the vent stack services only this drain. What is the best way to abandon the drain? Should I just cap it off? How do I abandon the vent pipe?
The PEX supply lines to the sink each have their own control valve at the manifold. Should I just turn off the valve and leave the pipe in place?
rgagnon22 is offline   Reply With Quote
Old 03-12-2012, 01:54 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
Cut the vent and waste lines where you want. Glue permanent caps on the ends
Terminate the pex lines near the manifold. I don't like to leave stagnate water lines in place.
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-21-2010 11:45 PM
Kitchen Sink Supply Lines Steven Z. Plumbing 3 04-02-2010 09:14 PM
