AAV Under Island Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2012, 12:10 PM   #1
Rewards Points: 198
AAV under island sink
My in-laws have an island sink. It drains slowly, I believe an AAV under the sink will help greatly. The issue is, the vertical pipe from the basement comes up and then a 90 turn to horizontal run of about 12" then another 90 turn and a horizontal run for 8" and then the trap.
The only easy place to put a T to an AAV would be after the second ninety, right before the trap---would this be OK?
benleef is offline   Reply With Quote
Old 12-03-2012, 12:44 PM   #2
Rewards Points: 2,494
Did you take the trap apart and see if there was any clogs?
You cannot use an AAV horizontal. Needs to be vertical or I think no more than 15 degrees from the vertical.
hammerlane is offline   Reply With Quote
Old 12-03-2012, 01:28 PM   #3
Rewards Points: 198
There are no clogs.
The T would be vertical not horizontal. Is it OK if it is vertical after a horizontal run, as long as it is before the trap?
Thanks!
Old 12-03-2012, 04:37 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
There are no clogs.
Thanks!
Best place for it is at the vertical to horizontal 90. If you can't replace that 90 with a tee- AAV on top then any place after that and before the trap will have to do
Old 12-03-2012, 05:12 PM   #5
Rewards Points: 198
That is what I figured. Thanks!
