AAV Kitchen Island Vent Code - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2011, 11:50 AM   #1
AAV kitchen island vent code
Adding a kitchen island and a vent isn't easily accessible. I tried to call my local building dept but they are closed this whole week on furlough.
Does anyone know if Air Admittance Valve vents are compliant with Hayward, CA building codes? Or where I can call and check to find out?
http://www.studor.com/mini-vent.htm
the-ls is offline   Reply With Quote
Old 12-31-2011, 12:11 AM   #2
Got the answer, mechanical venting is not allowed, so no.
Old 12-31-2011, 12:21 AM   #3
many years ago when i was in fla they would allow you to run a 3 inch line to an island sink and put a 3x1-1/2 tee on it for the drainand run the 3 inch up just under the countertop. since it was double the diameter of the minimum drain size it was self venting. I guess they approved it because 3 inch will carry 4 times what 1-1/2 will. some places would let you do a loop vent instead.
Old 12-31-2011, 12:06 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Ive seen oversized drains used before,another option might be an island/loop vent going back down through the floor to an area it can be tied back into a vent stack
plummen is offline   Reply With Quote
Old 12-31-2011, 01:36 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
Here in. Florida you can now run it in 2" with a AAV. i don't care for the set up but it works and it's ok under our code
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
2 Bathrooms and a Kitchen KevinACrider Project Showcase 16 10-31-2011 06:03 AM
10x10 Kitchen Set Work in this Kitchen ryanb4614 Remodeling 3 08-25-2011 07:48 PM
Question on CA code requirements for kitchen remodel (title 24) willow Electrical 8 07-22-2010 07:36 PM
Is this kitchen remodel code compliant? jheavner Electrical 18 10-07-2008 10:01 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
