Old 02-24-2009, 10:11 AM   #1
DIY'er
jamiedolan's Avatar
AAV for Dishwasher
HI,
Kitchen plans have changed around a bit during my remodel. Now my dishwasher drain will be about 5' - 6' away form the vent on 1.5" PVC. Can I put a AAV on the dishwasher to compensate?
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 02-24-2009, 10:55 AM   #2
AAV for Dishwasher
not sure your setup but why dont you but a in line trap . If the plumbing is vented properly then no problems
metx is offline   Reply With Quote
Old 02-24-2009, 11:41 AM   #3
AAV for Dishwasher
Basically, that would be the same as adding an air-gap on the countertop. Problem with air-gaps was that they clogged up and caused more problems than they solved. This is why many areas reversed the code on installing them. Are you tying into the sink drain line or disposer? I would suggest simply running a loop as high as possible under the countertop (as suggested in most DW installations) and see if that works for you.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
