Old 03-14-2009, 03:40 PM   #1
90 degree turn in horizontal 3" main drain
I hooked up my main 3" horizontal drain line so that the downhill end does a "short/small" 90 degree turn slants down again slightly for 2 feet and takes a wye to straight down. I didn't think much of it until I ran across the 1.5" "longer" 90 degree and was wondering if maybe it would be prudent to find a 3" "longer" 90 degree turn and use that in place of my short one. Is it worth it to try and switch to the longer more gradual turn or am I wondering about such a small difference. The 3" pipe drains a kitchen sink, dishwasher and washing machine.
wildbilly is offline   Reply With Quote
Old 03-14-2009, 04:29 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Short sweep 90s are not supposed to be used horizontally. The long sweep you saw is the minimum requirement. A better option, if room allows, is to use a tee-wye combo fitting (a wye and street 45) to make the turn. Put a fitting female adapter on the end with a clean out plug for future access.
JDC is offline   Reply With Quote
Old 03-14-2009, 06:52 PM   #3
Yeah, that makes sense JDC; Thanks!
I presume to put the arm of the wye upstream so that the cleanout plug would not be right on the end (of the flow) but on the side.
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
