Old 08-01-2010, 11:30 AM   #1
the Musigician
DangerMouse's Avatar
90° bend in 4" vent
Is it OK to put in a 90° bend to get the vent to where I need it? Or should I use 2 45° fittings? Or can I do this at ALL?
Thanks!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 08-01-2010, 11:33 AM   #2
Electrician
Proby's Avatar
90° bend in 4" vent
Is this for a dryer? Bathroom exhaust? It's best not to use 90's, but sometimes you have to. It's better to use (2) X 45's if you're able.
For plumbing vents, this doesn't apply.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-01-2010, 11:34 AM   #3
Owner
LateralConcepts's Avatar
90° bend in 4" vent
There's nothing wrong with that in a vent
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 08-01-2010, 11:37 AM   #4
call me E
TheEplumber's Avatar
90° bend in 4" vent
Are you in an attic, floor joists? What requires a 4" vent?
Old 08-01-2010, 11:38 AM   #5
the Musigician
90° bend in 4" vent
It's the main stack for the toilets, sinks, etc. through the roof. Where the drain is now, I need to move the toilets forward about a foot, and the vent back 6" or so to line up with a 6" wall to hide the ugleee tube. We had one right next to the toilet in our old house, and it looked like crap. I'm hiding everything, but leaving it as accessible as possible by planning it all out first. Ya never know when I might need to add a line for something....
DM
Old 08-01-2010, 11:43 AM   #6
the Musigician
90° bend in 4" vent
like so.....
Old 08-01-2010, 11:43 AM   #7
90° bend in 4" vent
As long as you maintain an upward sweep, you will be okay. I, too like to use 2 45's in case I ever need to clean it out. Easier to install now than wish you had, later, even though cleaning would probably never be required unless a squirrel fell down the vent pipe.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-01-2010, 11:46 AM   #8
the Musigician
90° bend in 4" vent
I think that'd be best, yup. 2X45° seems to be the way to go. I'll have a critter cap on the top though.
Po)
DM
Old 08-01-2010, 11:54 AM   #9
the Musigician
90° bend in 4" vent
Hmmm, it's going to be a tight fit with 45°ers, but it might just fit. If not though, the 90° is OK?
DM
Old 08-01-2010, 12:01 PM   #10
Licensed Master Plumber
90° bend in 4" vent
If the horizontal part of that 4" is below 6" above the highest fixture and it is not part of a wet vent then you can not do that. It must rise vertically.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 08-01-2010, 12:06 PM   #11
the Musigician
90° bend in 4" vent
It'd be a couple inches below the floor. Highest fixtures would be sinks....?
DM
Old 08-01-2010, 12:22 PM   #12
call me E
90° bend in 4" vent
Use 2 45's instead of 2 90's? It will still be considered vertical
Old 08-01-2010, 01:08 PM   #13
the Musigician
90° bend in 4" vent
I'm not so sure 2 45's will fit.... would this setup be acceptable? IT fits down there almost to the 1/4"! Puts the two toilet pipes right in line too!
Thanks!
DM
Old 08-01-2010, 01:43 PM   #14
90° bend in 4" vent
Technically....no
Old 08-01-2010, 01:52 PM   #15
the Musigician
90° bend in 4" vent
OK, two of these should still give me enough play to line up the vent through the 6" wall.... (I hope)
Thanks!
DM
4" PVC to 4" Lead Bend solidhomes Plumbing 0 07-20-2010 01:36 PM
Using 4" PVC for dryer vent Thurman Appliances 9 06-30-2010 11:44 PM
how to make 90 turn of 4" dryer vent in 2x4 wall hohadcr HVAC 5 03-15-2010 10:59 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
