70 Year Old Elbow Pipe--stripped Threading - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2011, 02:29 AM   #1
Question
70 year old Elbow Pipe--stripped threading
Hi All,
I have a toilet that is old, but dont have the cash to replace it at the moment.
The pipe connecting tank and pan leaks in one spot. I cant tell if it is the pipe itself or the gasket/sealant. what is the best options for fixing this? is this is a standard piece? The toilet is by Durock.
Many thanks in advance. I am new here.
70 year old Elbow Pipe--stripped threading-dsc00385.jpg   70 year old Elbow Pipe--stripped threading-dsc00384.jpg
New Son is offline   Reply With Quote
Old 07-11-2011, 07:43 AM   #2
Rewards Points: 1,418
Can you get replacment parts that fit?
If you can dry it off and press some toilet paper to the pipe before it leaks a large amount, that can help narrow down on although not foolporoolf foolproofly pinpoint the leak.
Old 07-11-2011, 08:25 AM   #3
Plumb or Die!
Undo the spud nut, you should be able to pull out the gasket that seals the connection. Likely it is 3/4s desintigrated. A plumbing supply house should be able to hook you up with a new gasket.
plumber666 is offline   Reply With Quote
Old 07-11-2011, 09:48 AM   #4
DIY staff
Rewards Points: 7,174
Consider a used toilet from the 'Re-Store' --Habitat for Humanitys junk outlet.
tpolk (07-11-2011)
Tags
elbow , leak , pipe , toilet
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 01:50 PM
Cutting pipe threading riverrite Plumbing 5 04-09-2010 08:13 AM
Need advice on fixing a leaky elbow on waterline below sink. JeffWireman Plumbing 2 03-12-2010 12:39 PM
How to cut a 20 year old soil pipe wibass Plumbing 3 06-21-2007 06:10 PM
