6yr, 9yr, 12yr HWT - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2011, 09:49 PM   #1
Electrician
Rewards Points: 802
6yr, 9yr, 12yr HWT
Hey so what is the difference between the 3 HWT. I have heard that the only difference is the sticker on the tank. Are you more or less paying an insurance premium with the 9yr and 12yr or is there better materials in these tanks.
Darren
darren is offline   Reply With Quote
Old 01-22-2011, 10:21 PM   #2
Do something
D'Brie's Avatar
Darren
Hi Darren,
You're correct, same tank, just buying an extended warranty.
D'Brie is offline   Reply With Quote
Old 01-22-2011, 10:58 PM   #3
Rewards Points: 150
Some require the rob to be replaced... at least it is supposed to be
Docwhitley is offline   Reply With Quote
Old 01-23-2011, 02:54 AM   #4
Homerepairguy's Avatar
Rewards Points: 998
Some heaters with longer warranties have two sacrificial anodes or one larger one. Worth the difference? I donno.
HRG
Homerepairguy is offline   Reply With Quote
Old 01-23-2011, 07:00 AM   #5
I always heard that the only difference was the price. Consumers had an article a couple of years ago that says there is a difference. Better insulation, more efficient burners, etc.
Old 01-23-2011, 07:14 AM   #6
Rewards Points: 1,216
When purchased my Whirlpool Electric Water Heater back in 2003 the only difference I noticed was the insulation factor so I went with it and figured OK better warranty and less $$ to operate.
I didn't notice any other differences but I would like to know if there are.
COLDIRON is offline   Reply With Quote
Old 01-23-2011, 12:45 PM   #7
Electrician
Rewards Points: 802
Thanks for the reply while were talking abot HWT, would you recommend a 40G or 60 gallon for a house with two adults and two kids under 5. Also is there any difference between top entry and side entry.
Old 01-23-2011, 02:27 PM   #8
40 gal should be fine for your family. Side and top probably not , whatever is convenience for hook up and space availability.
