6 Stage RO Filter Trouble - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2009, 01:42 PM   #1
6 stage RO filter trouble
I purchased a 6 stage Ro filter from ebay and did the install myself. I have no output from the Membrane filter to the De-orizedi 5th stage. when I took it apart I found a brass fitting on the tip of the output(not the waste line) it has a needle in the center it appears to be clogged. My water company claims 50-55 psi. I need help troubleshooting this fitting.
zombe1961 is offline   Reply With Quote
Old 07-08-2009, 01:48 PM   #2
Tired & Dirty
Rewards Points: 83
Zombie, A picture of fitting would make helping you allot easyer.
evapman is offline   Reply With Quote
Old 07-08-2009, 04:52 PM   #3
This is a couple of pics of the peice.
Old 07-16-2009, 11:02 PM   #4
That piece that you have is a check valve that is on the discharge of the membrane so that when it builds psi it does not come back into the membrane and go down the drain. It is probably fine and i would look at the automatic water shutoff. First is to take the line off that goes into the membrane and see if you have good flow and if so then that is fine. Turn it on with the output on the membrane disconnected and see if it drips any h2o out. if it doesn't than your capillary tube in the drain may be missing because you need back preasure on the drain to push product water through the membrane. If that dont work call a PROFESIONAL!! Ro's can be a pain in the A**!!
lilh2o3 is offline   Reply With Quote
Old 07-17-2009, 12:01 PM   #5
Red face
I have replaced the ASV. It makes Good water W/TDS of 30ppm 1gallon good to 4 waste. Even after the tank is full it will not shutoff. It just continues draining water.
Mike
Hog Hair Filter mjbxx HVAC 10 04-10-2009 08:46 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
How to confirm 2nd stage burner working? mirob HVAC 49 12-29-2008 06:11 PM
LSI thermostat stage settings trouble! weydoggy HVAC 1 11-27-2008 09:26 AM
Trouble finding correct filter size mitchv HVAC 8 10-16-2008 07:27 AM
