6 Pack Plumber - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2013, 08:37 PM   #16
Rewards Points: 43
Originally Posted by tylernt View Post
Hm, I had to tighten my compression stops onto my copper stub-outs really freaking tight, to the point where the started to groan, to stop them from leaking. Thought about using teflon to make the nuts easier to turn, but figured it was against code or something. Next time though I'll go ahead and use the tape!
I learned the hard way about how tight these suckers need to be - I felt like I was gonna bust the copper pipe in half at some point (in my head...I'm 99% sure i don't have the strength to crush a nut and ferrule and pipe all at once)
addfsd is offline   Reply With Quote
Old 04-16-2013, 01:36 PM   #17
Plumber
It becoming a real problem.
The ferrules are now 100% lead free and are not as soft as the old ones, this makes it more difficult to get a good seal between the ferrule and the copper.
DidIDoThat is offline   Reply With Quote
Old 04-16-2013, 11:00 PM   #18
Originally Posted by fetzer85
OP, where do those other lines go?
Pedestal sink and a claw foot tub...
Justgaff is offline   Reply With Quote
Old 04-17-2013, 05:23 AM   #19
Rewards Points: 1,280
Put a drop of lube oil or a dab of plumber's grease on the threads and tighten the nut one (1) round after all slack is removed. It's been that way since compression fittings were invented but the directions just aren't on the ferrule box anymore.
And The Leak Goes On!....Two Visits From the Plumber Later spyboy Plumbing 11 04-16-2011 09:12 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 01:23 PM
Help with gas pack trunk sizing justinNC HVAC 3 10-31-2009 08:38 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
