6 Pack Plumber - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2013, 07:27 PM   #1
6 pack plumber
I thought I would share this creative way of distributing water supply.
Justgaff is offline   Reply With Quote
Old 04-14-2013, 07:28 PM   #2
I should clarify that this is not my handiwork.... I would have used 1/4 turn valves anyways lol
Old 04-14-2013, 07:31 PM   #3
Rewards Points: 14,020
That on top of hardwood floors in a bathroom.
Old 04-14-2013, 07:34 PM   #4
Rewards Points: 6,652
If I had to guess, very old house turned into apartments. Most likely that bath used to be a bedroom.
Old 04-14-2013, 07:38 PM   #5
Yes a very old house with stone foundation. Gotta love the wood floors in a bathroom; this only scratches the surface of the stuff we've already fixed...
Old 04-14-2013, 07:54 PM   #6
Rewards Points: 236
Originally Posted by Justgaff View Post
Yes a very old house with stone foundation. .
is that square cut stone blocks, or actual stones ?
Fix'n it is offline   Reply With Quote
Old 04-14-2013, 08:09 PM   #7
Actual stones...
Old 04-14-2013, 09:03 PM   #8
Rewards Points: 236
Actual stones...
i seen a stone foundation, once. it was pretty darned cool. the base had to be "at least" 4' wide, and it tapered as it went up. pretty cool, i thought.
get some pics if you can.
Old 04-14-2013, 09:16 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 818
Got to give them some credit- every fixture has it's own shut off
Old 04-14-2013, 10:11 PM   #10
Actual stones...
Around here, we call that a Rubble foundation. Basically they would just pick up whatever stones where laying around, due to think about it, back then, you did not have the heavily populated areas, and in most areas that glaciers passed through, you would find foundations made of rubble.
Old 04-14-2013, 10:14 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
It might look ugly....but like Eplumber said...they used shut off's for each line......and...they used teflon tape....
Old 04-14-2013, 10:22 PM   #12
I was joking with my dad about using Teflon with compression fittings for toilet & sink hoses, and he even said that is a very old plumber trick, so that the fittings would not freeze over time, and you could get them apart, if they sat for ten-twenty years, or had very hard water in your area.
Old 04-15-2013, 12:39 PM   #13
Special User
Rewards Points: 1,230
Hm, I had to tighten my compression stops onto my copper stub-outs really freaking tight, to the point where the started to groan, to stop them from leaking. Thought about using teflon to make the nuts easier to turn, but figured it was against code or something. Next time though I'll go ahead and use the tape!
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 04-15-2013, 12:43 PM   #14
Plumber
Rewards Points: 818
I put a splash of teflon pipe dope on the threads to act as a lubricant- a little dab ol' do ya
The Following User Says Thank You to TheEplumber For This Useful Post:
BigJim (04-15-2013)
Old 04-15-2013, 01:12 PM   #15
Always learning...
fetzer85's Avatar
Rewards Points: 262
OP, where do those other lines go?
fetzer85 is offline   Reply With Quote
And The Leak Goes On!....Two Visits From the Plumber Later spyboy Plumbing 11 04-16-2011 09:12 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 01:23 PM
Help with gas pack trunk sizing justinNC HVAC 3 10-31-2009 08:38 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
