6" House Sewer Into 4" Lateral Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2013, 11:13 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 682
As I stated before, I know nothing about house traps because my area does not allow them, but whenever I come across a need for a special fitting I drop in or call my local supply houses. They have direct lines to wholesalers and manufacturers. If that trap is still required by your code then they will know where to get it.
The Following User Says Thank You to TheEplumber For This Useful Post:
Javiles (04-30-2013)
Old 05-01-2013, 05:50 PM   #17
Rewards Points: 1,956
Why are they putting that on if the storm is not draining into the sewer? Makes absolutely no sense.
Old 05-01-2013, 11:15 PM   #18
Master Plumber
Javiles's Avatar
Rewards Points: 996
I still think you should double check that lateral s down stream of that PVC something doesn't seem right
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
water main whine related to main sewer line? denemante Plumbing 4 03-07-2013 09:14 PM
Replace buried sewer line or install sewage pump? greendog Plumbing 0 04-07-2012 06:32 PM
Connecting drain trap to sewer line stonesnthread Plumbing 5 08-21-2011 12:58 PM
Sewer main line repair question dgeorge Plumbing 4 08-10-2011 07:21 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
