6" House Sewer Into 4" Lateral Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2013, 08:44 PM   #1
Rewards Points: 184
6" house sewer into 4" lateral line
Hello all,
Just purchased a single family foreclosure and discovered the house sewer in basement floor is 6" clay but the lateral line running from house to sewer main is 4" PVC. Apparently the former owners replaced the lateral line some time ago and there have been sewage backup problems ever since.
So now I have to run new 4" PVC in basement floor and tie into this existing 4" lateral line.
I just had a few questions about the existing lateral line for you pros out there before I start (please see pic):
1) Does the trap appear to be correct (besides replacing fitting with hole in it)?
2) Do I need a fresh air vent AND cleanout in lateral line? If so where does the vent go (before/after cleanout, before/after trap)?
3) There is a 3" line teed into the 4" lateral currently (this is for kitchen sink). Can this stay or do all underground lines need to be 4"?
4) Is anything else missing in lateral line?
stevekem is offline   Reply With Quote
Old 04-27-2013, 08:54 PM   #2
Rewards Points: 582
wow wonder why there is sewage problems..... would need to see alot more to say for certian what to do ...but for starters that whole mess need to be cut out.....that is a poor excuse for a trap....we never lay tees on there side and did i understand when you said ..inside is 6" clay into 4"
Old 04-27-2013, 08:55 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 554
See bold comments within quoted text
Originally Posted by stevekem View Post
Hello all,
1) Does the trap appear to be correct (besides replacing fitting with hole in it)?House traps are outlawed under UPC- surprised to see one in your line- I'd yank it
Clean out required for me.
3) There is a 3" line teed into the 4" lateral currently (this is for kitchen sink). Can this stay or do all underground lines need to be 4"?The tee should be a wye. Tees are not allowed in the position. Minimum line size = 2"
4) Is anything else missing in lateral line?Was it ever inspected? It would not have passed around my parts
The Following User Says Thank You to TheEplumber For This Useful Post:
LateralConcepts (04-27-2013)
Old 04-27-2013, 09:04 PM   #4
Rewards Points: 184
Thanks guys for the replies... Yes, the inside is 6" clay going into this 4" PVC. Also there was another trap (original) right before the 4" trap as well. Below is another pic showing the connection before we broke the clay a bit.
This lateral line was not inspected but I have to prepare it for the inspector to come and that's why I'm verifying what I need to do to correct it.
I had a local plumber out to cam the lateral line (thats how we discovered it was 4") and he said a trap is required on sewer line, can it vary in different parts of PA? I am near Pittsburgh.
If a trap is required, how should it look like?
Old 04-27-2013, 09:06 PM   #5
Rewards Points: 1,858
You only need a house trap if your downspouts and sewer all go to the treatment plant. That is called a combined sewer. If that is not the case remove it. While your at it also remove any tee fitting in the horizontal posistion and replace it with a Y fitting and a street 45.
Your inspector might not approve schdule 40 PVC outside. They sometimes prefer the thin wall stuff. You should call and find out.
Old 04-27-2013, 09:42 PM   #6
Rewards Points: 184
Thanks Ghostmaker... Our borough requires the downspouts to be separate from sewer...
So besides removing the trap and replacing the tee with a wye/45, anything else need done to bring to code?
I'm not sure if this is sch 40 or not, see pic below for closeup of pipe...
Old 04-27-2013, 11:31 PM   #7
Owner
LateralConcepts's Avatar
Wow that's a mess. Simple fix though. Are there traps on all of the other fixtures inside the house?
Not sure about code where you're located, but the 30/34 should be fine outside.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-27-2013, 11:39 PM   #8
Owner
I would suggest cutting it all out from downstream of the PVC "trap", back to the old clay coming out from under the foundation (including the clay trap), upstream of the 3" sanitary tee, and replace it all with 4" PVC (30/34 or SDR35). Replace the cleanout with a 4" WYE just as it is. Replace the 3" san. tee with a WYE and you should be "good to go". Literally. Check with your local AHJ (inspector) for what's required.
Lateral
(208) 818-8241
Old 04-28-2013, 06:08 AM   #9
That first trap to the left looks like whoever did that abortion used 45 degree fittings to get up to the angle of clay line . It's to much of an offset to be inline with clay. That's why they installed the clean out try a 22-1/2 degree. Then wye and 45 combo and replace clay trap with 4" pvc or whatever material that is.
joes plumbing is offline   Reply With Quote
Old 04-28-2013, 06:30 AM   #10
Rewards Points: 582
yep house trap is required in the pittsburgh and surrounding areas...should install new house trap then cleanout with fresh air as far as the kitchen install wye and 45 ...ben sr
Old 04-28-2013, 08:55 AM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 994
Not being familiar with the plumbing in your area i have a couple questions
1 whats down stream of the Micky mouse trap ?
2 am i looking at two incoming lines into that LAT ? one from the original home the second from an add on maybe ?
down here minimum size for a lateral is 6 inches is it possible that you have a larger line at some point past that newer PVC ? we do use traps but why have two of them unless you've added a new branch. that mess looks like a tap someone cut in to the clay and went pvc. sorry couldn't help just asking.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-28-2013, 05:57 PM   #12
Rewards Points: 184
Thanks for all the help.... Downstream of the trap runs straight into main sewer. The 3" line tapping in via tee is from an addition added on.
Regarding the trap/cleanout/fresh air vent, should it look like as shown in pic below (except for it would be outside)?
If so, is there a fitting like this available or is it built using various different fittings?
Is the trap portion built using 45's or do they sell 4" trap fittings?
Does the trap/cleanout/fresh air vent have to be within so many feet of house outside?
Old 04-30-2013, 06:34 PM   #13
Rewards Points: 184
I talked to the sewer authority today and got the specs on what they require.
Can anyone tell me where I can find a "handhole trap" as shown in diagram below?
I searched online but couldn't find anyone selling this. Is it called something else?
Old 04-30-2013, 10:00 PM   #14
Congrats on the house purchase! I am in the Mount Pleasant area, and we just converted from septic to sewage this past December, and a trap was required by the township as well. The traps the plumber installed I believe he referred to as a "running" trap, but I may be wrong. I pulled my paperwork from the conversion, and looked at the pictures I took, and the trap looks the same as the one on your picture, but it is only called a trap on the diagrams I have. I am sorry I don't have an exact answer, but hopefully this helps.
dan1554 is offline   Reply With Quote
Old 04-30-2013, 11:08 PM   #15
Rewards Points: 184
Thanks Dan for the reply. I'm getting some results when searching for "running trap" so maybe that's a more common term for them.
Can anyone verify if it is up to code to make the trap using (1) 4" PVC Return Bend, (1) 4" Sanitary Tee and (1) 4" Street 90 just like my drawing below?
water main whine related to main sewer line? denemante Plumbing 4 03-07-2013 09:14 PM
Replace buried sewer line or install sewage pump? greendog Plumbing 0 04-07-2012 06:32 PM
Connecting drain trap to sewer line stonesnthread Plumbing 5 08-21-2011 12:58 PM
Sewer main line repair question dgeorge Plumbing 4 08-10-2011 07:21 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
