6 Gallon Tank, Brown Water At Startup - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2011, 10:49 PM   #1
6 gallon tank, brown water at startup
We just installed a new 6 gallon hot water heater for our kitchen about 4 days ago.
This is its only source of hot water, due to a slab leak, it was the best, cost effective way.
That being said, the tank is brand new.
When we first turn on the water it spits out a bit of brown water, then clears up.
We havent used it that much, but feel it should be cleaned out by now.
Any idea what is causing this, and what can be done to fix this.
thanks
olivia
itascamace is offline   Reply With Quote
Old 03-08-2011, 11:05 PM   #2
Water Treatment
Rewards Points: 900
There might be some thing in the water like Iron or Manganese ... heat brings things like that out.
Akpsdvan is offline   Reply With Quote
Old 03-08-2011, 11:35 PM   #3
Rewards Points: 1,542
I think it is just sediment or dirt left over in the pipework from when you installed the heater. Give it another week to clear up, using a little water three or four times a day.
Old 03-09-2011, 12:22 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
It could be internal rust from a steel pipe nipple too. Is there any steel pipe in the new plumbing for the heater?
Mike Swearingen is offline   Reply With Quote
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 02:12 PM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
