54" Tub In 59" Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2012, 09:37 AM   #16
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by Alan View Post
Even better : don't replace them, just shave them down a bit. . . . Sawzall . . . Chainsaw. . . . . .
Now thats funny,i dont care who ya is!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-05-2012, 09:42 AM   #17
Rewards Points: 528
Yes it is, after all we know all plumbers carry a chainsaw in their toolbox.
framer52 is offline   Reply With Quote
Old 05-05-2012, 09:48 AM   #18
plummen's Avatar
I used to carry a stihl ms440 with a 30" bar in my cube van,I used to remove tree branches and other obstacles that got in my way when installing service drops for power lines.
I also used it to remove branches and junk when backhoeing in utilities across peoples yards,a little more scientific than destroying somebodies tree with a 710g extendahoe!
Old 05-05-2012, 11:26 AM   #19
All materials demo'd out-stud to stud measures 59x84x32.5-some load bearing walls here. Am ok with 54" tub-it's for 5 yr old son-will try to send pic of the space
Dbsrs01 is offline   Reply With Quote
Old 05-05-2012, 11:30 AM   #20
You guys have lost it-I'm out
Old 05-05-2012, 11:39 AM   #21
Rewards Points: 6,652
Nope, just typical contractor humor.
Old 05-05-2012, 12:56 PM   #22
Ok - just looking for help here
Old 05-05-2012, 01:14 PM   #23
plummen's Avatar
I lost it years ago,but Ive learned to work around it!
Anyway a picture of the end wall oppisite plumbing would definately help us visualize what youre up against here
Old 05-05-2012, 01:23 PM   #24
There is not much more anyone can do, other than the suggestions that have already been made.
Old 05-05-2012, 02:01 PM   #25
plummen's Avatar
Can the 2x4s be laid on their sides instead of edge on wall oppisite plumbing?
That would gain you an extra inch,kind of spinning wheels here without a picture
Old 05-05-2012, 02:11 PM   #26
Rewards Points: 150
Frame it to fit new tub
Back to helping.
Plummen is correct.
I did a quick check, there are panels for 54" tub surrounds. I'm not sure of the quality and variety.
Tiling is a more likely option, but I'm not a tiling expert. Build the new wall at the end oposite to the plumbing. I would only build the new wall 30" to 36" high then create a shelf back to the old wall. This will also give the perception of more shoulder room.
My wife doesn't allow me to use the chain saw in the house.
goosebarry is offline   Reply With Quote
The Following User Says Thank You to goosebarry For This Useful Post:
plummen (05-05-2012)
Old 05-05-2012, 03:01 PM   #27
Ok -that sounds like a plan- thank you-will also check out the panels that fit 54" tub-
Old 05-05-2012, 08:00 PM   #28
If you can't or don't want to try and squeeze that extra inch out(remember, kid won't always be 5) then i'd agree that you should frame it in to fit the tub up to about waist height and then kick it back out to the original wall. It's a great place to put shampoo etc.
Evstarr is offline   Reply With Quote
Crawl Space Issues / Too Many Layers of Floor jdmindy71 Flooring 1 12-31-2010 05:09 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Jacking Up Floor Joists in Tight Crawl Space killerformula Building & Construction 2 06-11-2009 03:23 PM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 03:29 PM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 06:32 PM
