54" Tub In 59" Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 09:42 PM   #1
Question
54" tub in 59" space
Had leak in old shower pan in tiled shower on second floor - tore out whole thing back to studs-got 54" tub to replace-what do I do with the extra 5 inches-do I need cement boards on walls if I use surround panels-what support is required -just place tub on subfloor? With ledger board-do I need floor protection on top of subfloor?
Dbsrs01 is offline   Reply With Quote
Old 05-04-2012, 09:51 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it a tub only or a tub/shower?
Journeyman Plumber
Old 05-04-2012, 10:04 PM   #3
Rewards Points: 6,652
Suggest looking at Mobile home supply houses.
Old 05-04-2012, 10:06 PM   #4
Tub shower
Old 05-04-2012, 10:26 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Frame it to fit new tub
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-04-2012, 10:27 PM   #6
Why mobile home supply?
Old 05-04-2012, 10:31 PM   #7
Doing it myself
Alan's Avatar
Have you already got the tub?
I'd definitely reccomend doing something that will allow you to get a 60" unit in there.
You will be much happier. Besides, it's only an inch.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
jaydevries (05-04-2012)
Old 05-04-2012, 10:52 PM   #8
Already have tub-was told there was no way to get standard size in space by several overpriced contractors
Old 05-04-2012, 11:24 PM   #9
Homerepairguy's Avatar
Rewards Points: 998
+1 not only for the tub but also for sliding shower doors.
Since it's a tub/shower, if you're planning to install sliding doors, the shower doors will be rated for 54" to 59.5" width. On a 54" tub there will be a large overlap of the doors, plus the width to get in and out of the tub will be smaller. You will still be able to get in/out of the tub but the 60" installation looks better and is more functional.
HRG
Homerepairguy is offline   Reply With Quote
Old 05-04-2012, 11:29 PM   #10
No shower door planned-but if I wanted to change the plan - how do you put a 60 inch tub in a 59" space
Old 05-04-2012, 11:30 PM   #11
plummen's Avatar
How about a picture of the area?
Old 05-04-2012, 11:52 PM   #12
Picture on iPhone-not sure how to attach to message here-
Old 05-05-2012, 12:57 AM   #13
Rewards Points: 150
Are you measuring with the wallboard and/or tile in place? 60" tub fits in the rough opening measured without wallboard.
Could you replace one wall with a wall built with 2 x 3 instead of 2 x 4 studs?
goosebarry is offline   Reply With Quote
The Following User Says Thank You to goosebarry For This Useful Post:
plummen (05-05-2012)
Old 05-05-2012, 09:04 AM   #14
They sell smaller sized units than what you can get through conventional hardware stores.
Old 05-05-2012, 09:35 AM   #15
Doing it myself
Alan's Avatar
Even better : don't replace them, just shave them down a bit. . . . Sawzall . . . Chainsaw. . . . . .
Journeyman Plumber
Crawl Space Issues / Too Many Layers of Floor jdmindy71 Flooring 1 12-31-2010 05:09 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Jacking Up Floor Joists in Tight Crawl Space killerformula Building & Construction 2 06-11-2009 03:23 PM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 03:29 PM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 06:32 PM
