5/8 Water Meter With A 1 Inch Servise Line ????? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 10:33 AM   #1
5/8 water meter with a 1 inch servise line ?????
My Photos
5/8 water meter with a 1 inch servise line????
Hi to all im currently doing a job.... im replacing the servise line, its a 5/8 water meter and i want to install a 1 inch line from the meter to the house now i really didnt like the idea do to the fact that the meter is 5/8 .and the inside of the meter is 3/4. and ones the line is inside the house is going to have to be reduse to 3/4 inch anyways.what do you guys suggest is the best line for the house a 1 inch line from the meter to the house or a 3/4 inch line witch is currently in place . the run from the meter to the inside of the garage is about 50 feet i want the best available pressure and volume and would rather pick the best size line
ogoz23 is offline   Reply With Quote
Old 01-31-2012, 05:00 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 994
There is a fixture load table you have to follow, depending on the amount of toilets tubs sinks etc, also single story , 2 – 3 floors, and depending what code your under. Pipe sizing, each fixture has a load factor add them up and you get the required main water service size needed to supply the home.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-31-2012, 05:35 PM   #3
Rewards Points: 13,450
Has anyone here ever even heard of a 5/8 pipe size. I know I have not.
3/4, 1" yes 5/8 no.
It's not even on the NPT thread charts.
Old 01-31-2012, 06:07 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 994
I think what he meant was the size of the water meter most residential meters are 5/8 its stamped on the meters, that’s where he got the 5/8 from.
The Following User Says Thank You to Javiles For This Useful Post:
ben's plumbing (01-31-2012)
Old 01-31-2012, 06:42 PM   #5
Rewards Points: 582
yes 5/8 is the size of meter tail piece...if you use a standard 3/4 copper you should be fine under normal conditions....as mentioned how much is load...
Old 01-31-2012, 07:04 PM   #6
Yea 5/8 is the size of the water meter and the inside is 3/4 inch ........right now I have 3 bathrooms but even if the load is fine with the 3/4 inch service line I want to know if the 1 inch line would be better or if it would hurt my pressure
Old 01-31-2012, 07:11 PM   #7
Rewards Points: 582
it should not hurt your pressure by installing 1" you would increase your volume... so really it would be better as you are thinking...
Old 02-01-2012, 07:15 PM   #8
Ok I will be running the 1 inch service line this weekend ,, it will be flexible copper grade (K) ....I'm also going to sleeve it with a 1 1/2 sleeve I will be taking pictures to share this project with you guys.
The Following User Says Thank You to ogoz23 For This Useful Post:
ben's plumbing (02-01-2012)
Old 02-01-2012, 09:58 PM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
3/4, 1" yes 5/8 no.
5/8" would more likely be found in an old refrigiration system where they measure o.d of pipe which would be 5/8 o.d = 1/2" i.d tubing.
Anyway the smallest tap weve been able to get around here for a new service has been for 1" copper for the past few years
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-02-2012, 07:40 AM   #10
Rewards Points: 150
3/4, 1" yes 5/8 no.
In Canada, back in the late 60's, 5/8" copper was a very common material from the watermain to the property line. In new subdivisions and reconstructions, 1" service is the standard in the city I work at.
psilva8 is offline   Reply With Quote
Old 02-02-2012, 05:48 PM   #11
5/8 Is the size of the water meter for does of you who are confuse just think of it like the inside is 3/4
The Following 2 Users Say Thank You to ogoz23 For This Useful Post:
ben's plumbing (02-02-2012), plummen (02-02-2012)
Old 02-04-2012, 10:35 PM   #12
Well there is the service line ,1 inch flexible copper with a 1 1/2 sleeve so far so good the line in a foot deep no major problems tomorrow I'm running the plumbing in the house
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water coming through cold water line mrdojo Plumbing 0 01-26-2012 04:19 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
