4inch CI Waste Under The Basement (join To PVC) - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2011, 07:00 PM   #1
SFX Group's Avatar
Send a message via MSN to SFX Group Send a message via Skype™ to SFX Group
4inch CI waste under the basement (join to PVC)
Hi all
Ive done alot of reading on this, the house is c.1940-1945.
I need to dig up the orginal waste pipe in the basement, its 4inch CI with a really basic clear out, the idea will be to (under the floor) break off the old CI and connect it with a Fernco then fasion a new clear out. All bends are sweep as needed (as no designs in complete yet)
Thought i would check, i am ok with putting a shielded Fernco under the floor then covering with concrete?
Overview
4inch CI > Fernco shielded 4 clamp > 4inch PVC glued to 3inch PVC
[4CI > clamp > 4PVC > glue > 4to3 PVC]
CLAMP
I am still playing with either 4CI > 4PVC or 4CI > 3PVC with the above clamps, your input would be good.
This is in Canada where the ground does get below -10 in the winter. While here, whats the best way to dig up the old pipe and cut it to a nice finish without shattering the pipe before i get to it?
Many Thanks
Ashley
Copyright 2011 - www.ashleygriffin.ca
SFX Group is offline   Reply With Quote
Old 01-16-2011, 07:08 PM   #2
In regards to getting a nice cut with a smooth finish, I just cut my 3" CI drain pipe with a diamond blade in an angle grinder. I made it through the cut in maybe a minute with a super smooth edge remaining. I tried a sawzall first and it was doing a pitiful job before I remembered that I had the angle grinder.
rkerns is offline   Reply With Quote
Old 01-16-2011, 07:33 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 356
yes you can put a shield coupling under concrete.
Over insulate basement? braverichard Building & Construction 26 06-22-2010 09:26 PM
Basement Rough in PSULion55 Plumbing 1 02-06-2010 01:44 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
