45 Degree Water Base Heat - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2010, 10:03 PM   #1
45 degree water base heat
I woud like to know and locate a piece needed to cover the water base heat pipe that is angled at 45 degree. Here is why.
A contractor added cabinets, base and wall hung, along the wall that had water base heat in the kitchen. The piping then be installed along the adjacent wall which is the exterior wall. Along that wall is a bay window with the bottom flush with the floor all the way up close to the ceiling. The sides of the bay are angled at 45 degree, and the pipe follows along the wall. The contractor left without putting the cover on along the 45^ walls.
Is there a 45^ cover for the corners? If not, any suggestion?
Thanks for the inputs.
Eagle2 is offline   Reply With Quote
Old 01-23-2010, 10:16 PM   #2
Did you already pay him in full? No way to get him to come back?
Most baseboard manufacturers make 45^ caps. Maybe they're on back order?
If you're not sure what kind of baseboard they used (i.e.- what manufacturer), the best thing would be to take one of the regular end caps to a real plumbing wholesaler (not a Home Depot) and ask them if they recognize the make. They may be able to get some 45^ caps for you.
Ishmael is offline   Reply With Quote
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
water dripping from heat vents pamleo HVAC 8 01-28-2009 10:40 PM
Finned-tube elements for hot water baseboard heat SureBert HVAC 2 12-05-2008 06:01 PM
