44" Wide Shower Stall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2013, 10:22 AM   #1
44" wide shower stall?
Hey guys and gals!
I'm in the process of adding a full bath to my basement. I haven't framed up the walls yet, but have done some calculations and will end up with a 44" wide area to put a shower stall. I've been looking at the big box store websites and I guess standard sizes are either 48" or 42".
Do you know of anybody that makes a 44" wide stall?
If I do have to go with the 42" stall, how do you suggest I frame out the opening? Take an inch from either side or take the full 2" from one side? I suppose it's just personal preference.
Thanks!
Skull Leader is offline   Reply With Quote
Old 08-16-2013, 02:14 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
You're pretty much stuck with a 42"
How you get to 42" is up to you
Something else to consider- is will the unit fit through all your doors
Sent from my iPhone using DIY Forum. Watch out for spell check
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (08-17-2013)
Old 08-16-2013, 03:31 PM   #3
Oh, good point! I hadn't thought about that. As long as it's a two(base and walls) or more piece I can make it work.
Old 08-17-2013, 02:18 PM   #4
Rewards Points: 177
Why not just make your own shower base and tile everything.
paul100 is offline   Reply With Quote
The Following 2 Users Say Thank You to paul100 For This Useful Post:
oh'mike (08-17-2013), plummen (08-17-2013)
Shower stall halfway finished. Need some help. Zefrik Drywall & Plaster 3 07-29-2012 11:46 AM
leaking - tiled shower stall jbeazer908 Tiling, ceramics, marble 4 07-07-2012 05:59 PM
what is best way to build shower stall ? dragonflysfo Tiling, ceramics, marble 2 11-20-2011 08:53 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
installing lights in shower stall mcvane Electrical 2 03-30-2007 05:34 AM
