Is $4000 Too Much To Replace Toilet Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Closed Thread
Old 02-17-2010, 12:07 PM   #1
Is $4000 too much to replace toilet vent?
My problem started with water/sewage backing up in shower and coming out of bottom of toilet. The shower, sink, and toilet are all side by side and use the same drain pipe to the septic tank. I took the toilet off and had a plumber come to snake, scope, and clean the line. They discovered the drain, which goes to the left of shower was clean and instead found that the the toilet's vent pipe which goes to the right had broken underground and closed off. The toilet sits in front of the bathroom window and on the other side of the window the vent pipe comes out of the ground. The plumber says that to replace the vent pipe will cost $4000, which seems high to me. Can anyone suggest alternatives/questions I could ask the plumber? Thanks.
watch_hill is offline
Old 02-17-2010, 12:52 PM   #2
This site is geared towards DIY, not cost estimates
Prices vary widely by area & the specific job
Get several local estimates & check references
Thank you
-Moderator
Scuba_Dave is offline
Closed Thread
Frozen Vent Pipe Ratchye Plumbing 55 01-17-2017 05:21 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath Heikks2002 Plumbing 3 01-15-2010 10:21 AM
Toilet vent pipe clean out bdionne Plumbing 3 12-26-2009 08:13 PM
Vent line for toilet eahosea Plumbing 7 12-03-2009 09:35 PM
