40-60 Pressure Square "D" Switch - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2012, 05:52 AM   #1
40-60 pressure square "D" switch
I just installed a new Square D 40-60 pressure switch and adjusted it to around 38-50. I came home from work and the aerator tank was very low. When I took the cover off the switch I carefully pushed the contacts together and ran up to 70 and I had cut it off. Then I drained the water pressure to 50 and it ran fine after a few days then it started the bad cycle again. I also noticed the contact points are off set at times is this normal? Is it a bad switch or can I adjust it?
clyde10 is offline   Reply With Quote
Old 05-12-2012, 06:55 PM   #2
Rewards Points: 350
You read the installation instructions, right? Been awhile since I did mine, but I think it went like this:
Drain all water from the tank.
Pressurize the tank to about 2 pds below the low range ( so 38 pds).
Apply electricity.
If you don't drain it first, (and in so doing, bring the pressure down to something very low), it won't work right.
The instructions should also tell you if you loosen the nut, it is about (I think) 4 pounds for every FULL turn.
Good luck!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 05-12-2012, 10:06 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You don't have to drain it to adjust the switch AFAIK, just to adjust the pressure tank.
Journeyman Plumber
Old 05-13-2012, 06:01 AM   #4
Thanks for the information. I did not realize the bladder pressure in the tank had something to do with the pressure switch. I do not think I lost any pressure in the tank but sure will check it.
Old 05-13-2012, 11:34 AM   #5
Doing it myself
Alan's Avatar
Note my post above. You do need to let the water pressure off the system before checking the pressure in the bladder tank. It should be about 2psi below the cut on pressure of the switch.
Journeyman Plumber
Old 05-13-2012, 12:48 PM   #6
Rewards Points: 636
just a general question why is it that people want to adjust a factory set switch out of the box
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 07:53 PM
pressure switch stuck open pr1244883 HVAC 6 05-15-2011 11:55 PM
Pressure switch ratings gp_wa Electrical 6 08-31-2009 09:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
