#1 |
4 Yr Old - AO Smith 50 Gallon Won't Relight?
i have a 5 yr old 50 galllon ao smith gas water heater, no hot water starting yesterday night....... tried to light pilor a dozen times, but no luck. cannot seem to get it lit again... i have followed book & instruction on water heater to relight, but no luck... this is how i tried to relight.....IN THE OFF POSITION, I TURNED KNOB TO PILOT, PUSHED DOWN, PRESS THE IGNITOR BUTTON NUMEROUS TIMES, BUT NO LUCK.... on a couple of OCCASION, did seen to see a small spark inside the small glass window,,, .... i googled this model, appears this tank may have problems? anyone have an opinion.
#2 |
Thermocouple? That is usually the culprit. My understanding, correct me if I'm wrong, is that you won't be able to relight if you need a new thermocouple.
#3 |
Super Moderator
When a thermo coupling fails you can relight the pilot--but it will go out as soon as you let go of the button.
OP can't get the pilot to light at all---Often simply turning the valve to 'OFF'--then 'PILOT' and hold the button down for one minute--then hit the clicker ---will work---it's worth a try. ---Mike--
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| A.O. Smith Vertex vs Vertex 100 vs 75 gallon tank. | TopRowSeat | Plumbing | 7 | 01-11-2012 04:15 PM |
| Bayer liquid weed killer & 2 Gallon flomaster pressure sprayer combo pack @ HD $10 | whataboutj | Landscaping & Lawn Care | 25 | 05-13-2010 11:01 PM |
| What are you paying for a gallon of paint? | Git | Painting | 8 | 09-23-2008 11:59 PM |
| Is a 40 Gallon water heater electric enough for a 1 bath house (2 people). | twilightcall | Plumbing | 6 | 08-06-2008 10:11 AM |
