Old 07-24-2007, 05:31 PM   #1
Unhappy
4 inch 90 degree PVC elbow w/2 inch heel inlet
i need this but all i could find at HD and ferguson was the 3 inch version. was wondering if anyone has suggestions or at least a viable explanation as to why it is unavailable ?
thanks,
- a
Old 07-24-2007, 07:16 PM   #2
zel
Send a message via AIM to zel
Try a plumbing supply store. The big stores only seem to carry the "most common" stuff. I've been burned by them alot lately.
zel is offline   Reply With Quote
Old 07-25-2007, 09:49 PM   #3
can you use a 4" with a reducer?
redline is offline   Reply With Quote
Old 07-26-2007, 10:32 PM   #4
Journeyman Plumber
Ron The Plumber's Avatar
There are no 4" low heal inlets.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 07-27-2007, 11:55 AM   #5
If I remember correctly, Mueller Industries makes one, but it is not a long-sweep bend. You may want to check there.
Manuel6 is offline   Reply With Quote
Old 07-27-2007, 07:59 PM   #6
Union HVAC Tech.
Charlotte Pipe makes them in pvc part #303 1/4 bend with low heel inlet 4"x4"x2"
And I'm sure GSR and several other companies make them also.
bigMikeB is offline   Reply With Quote
