Old 05-06-2007, 12:04 AM   #1
Question 4" Hole for portable air conditioner
Hey everyone....first timer here, and already I have one for you all. I am wanting to air condtion my garage, so I insulated the garage door panels with foylon, and just picked up a DeLonghi CF210 Portable Air Conditioner. It has a 4" hose that needs to be run through the wall to the outside of the garage. Inside of my garage is standard sheetrock, with the outside being good ol' red brick. My question is, how do I go about getting this 4" hole through the inside of my garage through the brick wall??????
Thanks all for any input you may give me.
bossman7076 is offline   Reply With Quote
Old 05-06-2007, 12:35 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You can rent a roto-hammer and also rent a mason boring bit to drill out the hole you need. Drill from outside in, make sure you know where studs are located so you don't hit one on center.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-06-2007, 01:00 AM   #3
Using a chisel or a drill with a masonry bit, remove the mortar and necessary bricks until the hole is large enough. I would draw a circle pattern, drill holes, and then hammer it out.
handy man88 is offline   Reply With Quote
More On This Topic
Hi this is Jon, and in this clip we'll be removing the Brickmold. On the exterior side of our door, we have our Brickmold that goes all the way around our door, similar to the trim on the other side. But, this is more weather resistant since it is on the... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. I want to tell you why in two different ways. Number one, if your unit is in the garage and the holes are on the... Read More »
I'm Chad I present motorcycles in Wilmington, North Carolina on behalf of expertvillage.com I'm here to show you some of my maintenance on our bike before you go out for a ride. Now we are going to talk about some of the tools that we use today that you... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
My name is Shannon Kniep on behalf of Expert Village, I'm going to show you how to cut a piece of sheetrock. We got the measurements up on our ceiling which is what we need in order to know the size of the piece that's going to fit in there. And it is... Read More »
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 08:14 PM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-19-2007 12:45 AM
Lasco Hole Punch 15-5562P joecodi Tools 0 06-01-2007 12:56 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 09:17 AM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 12:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
