4" Gutter -> 3" Sewer Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2009, 07:30 PM   #1
Rewards Points: 1,062
Question
4" gutter -> 3" sewer pipe
i was contemplating a redesign of my gutter system and was wondering if it would be to constricting to conduct my 4 inch gutter into a conveniently located 3 inch pipe that is buried nearby ?
Old 08-19-2009, 08:03 AM   #2
Rewards Points: 1,512
It might overflow in the heaviest of rain storms.
WHere does the 3 inch pipe lead to?
Do not run rain water or gutter water into a septic system or into a dry well used for household drains. Also do not run into a perimeter drain (aka French drain, weeping tile) system for the house unless you have a sump pump and need/want that to help get rid of the water.
Old 08-19-2009, 11:48 AM   #3
Rewards Points: 1,580
I don't think you'll have a problem. A 4" gutter doesn't empty into a 4" round downspout; the outlet on a 4" gutter is likely a 2"x3" oval (6 sq in) at best. A 3" round PVC will be 9.4 sq in. If it overflows, then think about replacing the 3" but I doubt it will.
bob22 is offline   Reply With Quote
Old 08-22-2009, 09:05 PM   #4
It really depends on how much square footage of roof your draining into that 4" gutter. But unless it's a really big area draining into that gutter, I would imagine a 3" drainage pipe would be fine.
I have a modest sized ranch home (approz 1200 square feet) and my rear downspout drains into a 3" pipe. The pipe steps up to 4" where my front downspot ties into it. No problems with the volume.
pkovo is offline   Reply With Quote
Old 08-22-2009, 09:48 PM   #5
GC/Master Plumber/Mech
Rewards Points: 560
Should be fine. There are adapters made to do this.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
cant get 3" cleanout out of 4" cast iron pipe Leoskee Plumbing 14 08-03-2009 08:30 AM
Dynamics of 3" vs 4 " main sewer line 4just1don Plumbing 4 01-07-2009 07:01 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
Hooking New Bath into Sewer Pipe jasoncw Plumbing 4 03-04-2008 04:42 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
