4" Drain For Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2010, 09:10 AM   #31
the Musigician
DangerMouse's Avatar
Ok then.... how do I get two toilets and the 2" sink drains to drain to this 3" pipe?
Any graphics like before of a 'common' configuration I can see anywhere?
I have around 3' of room from concrete to flooring above down there to work in.
The straight 'out' pipe I'll be connecting to is already 8 or so inches from the floor.
Thanks for your patience everyone!
Man, I feel like such a......
DM
Old 08-03-2010, 08:20 PM   #32
Plumber
TheEplumber's Avatar
Rewards Points: 684
A 3" pipe is plenty for the fixtures you list but I'm not in your proposed bathrms so I see where to put your lavs or toilets. Put 6 different plumbers in there and you'll get 6 different layouts.
Old 08-03-2010, 08:25 PM   #33
Owner
LateralConcepts's Avatar
...or put DangerMouse in there and you'll get 30 different layouts
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-04-2010, 06:07 AM   #34
the Musigician
more like 100.... and all wrong!
DM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Tapping an existing 4" PVC yard drain crza1 Landscaping & Lawn Care 5 06-04-2010 02:16 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
