4" Drain For Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2010, 02:36 PM   #1
the Musigician
DangerMouse's Avatar
4" drain for toilet?
I was just told I should use a 4 way (double "Y"?) tee for my toilets to drain down to, is this a better way to go? The long swooping sanitary 4"X 4 way is a 'special order' ...even from the big plumbing supply place! Expensive too....
Is 4" toilet draining that uncommon? It's what's in here NOW and has always performed admirably!
When I moved in all I did was replace the water lines, I did nothing to the drains as they were fine. So I'm kinda new to drains/vents.... but I'm learning fast!
Thanks everyone!
DM
Old 08-02-2010, 02:42 PM   #2
Rewards Points: 272
I used a 4" sch40 sanitary T when I redid mine in April. Special order? Not at my local plumbing shop. Seems like a pretty common item to me. I know some people use 3" pipe for toilet drains but since my main stack was 4" I just went with it instead of the smaller line.
speedster1 is offline   Reply With Quote
Old 08-02-2010, 02:43 PM   #3
Owner
LateralConcepts's Avatar
$9 Google it
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-02-2010, 02:46 PM   #4
the Musigician
My son is 6' 5" so he leaves rather large "product" sometimes!
Between the 4" pipes and my FlushMateŽ toilet, we rarely have a problem. Po)
I'd like it to continue this way.
DM
Old 08-02-2010, 02:50 PM   #5
the Musigician
Where is it $9.00??? I paid over 20 for the wrong one!
The swooping one is larger and costs more, I'm sure!
So.... would it be better/OK to use the 45° "Y" tee and 2 more 4" 45° turns to the 2 toilets?
Thanks!
DM
Old 08-02-2010, 02:52 PM   #6
Owner
Yes use the double WYE and street 45's.
http://www.acehardwareoutlet.com/pro...rce=GoogleBase
Lateral
(208) 818-8241
Old 08-02-2010, 02:54 PM   #7
Owner
Sorry just noticed that one's 3" but 4" is probably only a couple bucks more.
Lateral
(208) 818-8241
Old 08-02-2010, 02:56 PM   #8
Owner
Just searched again. I was wrong. $28.99 but shop around. Your local wholesale supply should be less than that.
Lateral
(208) 818-8241
Old 08-02-2010, 02:57 PM   #9
the Musigician
At HD the 3" was like $7.00, but the 4" was $21 or $22?
Seemed like a helluva markup for so little added plastic to me too!
DM
Old 08-02-2010, 02:58 PM   #10
the Musigician
-=chuckle=- screw it, as long as the street 45°s are good, I'll go that route.
The wife already knows what they look like and where they are at HD and she's in town today! lol
DM
Old 08-02-2010, 03:05 PM   #11
Owner
DM
Yeah kinda silly. That's why most new construction you find it 3". Ok by code, but 4" is still better.
A toilet is only as good as the pipe under it.
Like the Kohler commercials are silly that show a guy flushin' towels, etc. down to stop the hot female plumber...
Guess that's what keeps the service guys in business. Haha
Lateral
(208) 818-8241
Old 08-02-2010, 05:12 PM   #12
the Musigician
Well, I called the HD and had them hold the 3 pieces at the service desk for her. It was $21 for the double wye tee and $5 something each for the street 45s.... So it's not THAT much more to be able to sleep easier tonight knowing the inspector will be happy. Po)
One more 4" 10'er and I'll be good to have him come out and see how I intend to set it up. I'll set the pieces in place and duct tape if necessary. I'm pretty sure that now, thanks so much to all here who have helped me, I'll pass with little or no changes.
(If they have to answer too many questions, there's a $50.00 "consultation" fee)
DM
Old 08-02-2010, 06:55 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 562
As most of us realize, plumbing codes and inspectors interpretation vary. I work with 5 different variations within 100 mile area. I suggested a fixture cross to you because it is the prefered fitting here. Another option is a 4x3 sanitary cross. 3" is typical for a toilet trap arm. You can put 3 toilets on a 3" horz. pipe.
Look at the profile of a sanitary cross and imagine snaking your main through 1 toilet and hearing rattle in the one next door because it jumped across the dble san tee. There is a good chance your toilet flush will do the same thing. A portion of it will jump the cross and backwash the other toilet arm. A fixture cross is a little more directional than san cross. A double y with st 45's is flat out wrong. It will not vent properly.
Thats my 2 cents
Old 08-02-2010, 07:58 PM   #14
the Musigician
So....Lateral Concepts is wrong and I cannot USE the 3 pieces the wife already bought and paid for?????
AARGH!!! You're kidding, right? I HAD the white one already, that was wrong.... I don't think I can USE a black one with my white pvc without some special cement, and they don't have one anyways. How will the venting be any different using a double wye 4" 4 way? same thing basically, and the 4" vent is right in the middle of the two?
Confused again, as usual.....
DM
Old 08-02-2010, 08:11 PM   #15
Plumber
Rewards Points: 562
As I said- you can use a cross but try to use 4x4x3x3 3" is your branch size to your toilets(more than ample)
And the pix of the fixture cross is available in pvc too I just happened to find abs
You can try the dble wye if you want. I want to hear your inspectors response
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Tapping an existing 4" PVC yard drain crza1 Landscaping & Lawn Care 5 06-04-2010 02:16 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
