Old 07-25-2010, 01:30 PM   #1
4" closet flange in basement bathroom
In the image is a 4" toilet flange on top of a 4" 90 sweep. (new basement bathroom)
I need to cement the floor to make it level. My concern is that I will need to raise the toilet flange.
What type of fitting is needed to do this?
I would rather not raise ALL of the drain pipe in order for the flange to be level with the floor.
n2learning is offline   Reply With Quote
Old 07-25-2010, 02:06 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A toilet flange should sit flush on top of the finished floor level and be bolted to the floor.
You can get extensions to raise the level of the flange, if it has already been glued to the 90.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-25-2010, 02:52 PM   #3
Mike,
The flange is not glued in yet. Should I just remove the flange and just add some 4" pvc (maybe 6" or so) and then when I am ready to add the flange, cut off the pvc and find a flange that fits inside the 4" diameter?
Old 07-25-2010, 04:04 PM   #4
Long-Time DIYer
That sounds like a very good plan.
Good Luck!
Mike
How to anchor toilet flange to porcelain tile? bobmg Plumbing 29 03-30-2012 12:09 PM
Completing a roughed in basement bathroom Bob in St. Louis Plumbing 8 11-18-2011 01:12 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 09:22 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
