Old 11-28-2007, 10:39 PM   #1
Send a message via Yahoo to fburke
3” vent pipe through Granite foundation
I need to boar a 3” hole through a granite block foundation for a direct vent gas boiler. Any suggestion o what to use for this?
fburke is offline   Reply With Quote
Old 11-28-2007, 10:52 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Rent a 3" core bit and drill it out.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 11-28-2007, 11:00 PM   #3
is this somthing i should be able to rent at Home Depot??
....my local tool rental place looked at me like I had 3 heads..not vey helpful at all..
Old 11-28-2007, 11:13 PM   #4
ICF Construction
I highly doubt Home Depot has them either. Look around for a United Rental or something similar.
Two options
1) Hand Held - i.e. Hilte with 3" core bit
2) Mounted Unit - i.e. Milwaukee bolt to wall and hook garden hose up, start drilling.
#2 is a lot easier on the arms, and a wet mess to clean up
#1 is going to feel like it is taking forever and dust galore (keep the shop vac going if inside)
Both have a price #1 is cheaper than #2
Chris
Chris Johnson is offline   Reply With Quote
Old 11-29-2007, 06:47 PM   #5
Send a message via AIM to Marlin
The core drill is defiantly the way to go. Last time I drilled granite with a core drill it took about twenty minutes. It probably would have taken an hour or better trying to drill it with a hand held drill and that's if you could even get it started.
Their is a bit involved with core drilling, it's pretty simple but their is a learning curve. To mount the core drill on the wall you will need some way of fastening it to the wall. Usually you use a double expansion anchor. Drill a hole with a 3/4 bit then get your anchor set by putting a piece of threaded rod in it, place it in the hole you just drilled, then tighten a washer and nut onto it to expand it and lock it into the foundation. You can then mount the drill on the rod. Remember that the hole you drill will be below the 3/4 hole whatever distance it is from the mounting point on the drill stand to the center of the drill itself.
Marlin is offline   Reply With Quote
vent pipe jenry93 Safety 2 09-15-2007 06:41 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 10:45 PM
