3" Toilet Flapper Keeps Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2016, 04:57 PM   #1
Rewards Points: 101
3" Toilet flapper keeps leaking
I have a toilet the kept running so I replaced the toilet flapper. It was a larger hole so I got a 3" flapper. It was one of those cloud master adjustable ones. I just found the toilet leaking again and it seems the flapper is able to slide side to side quite a bit on the hinge. Enough to that apparently it can land quite off center and on a ridge that goes around the center bulb.
Assuming all this makes sense to you guys, does anyone have an idea how to fix this. I'm used to the smaller standard size holes (2" I guess). Not sure what the options are for these.
wvphysics is offline   Reply With Quote
Old 01-11-2016, 07:32 PM   #2
Rewards Points: 320
Possibly the wrong flapper for your toilet. What's the brand of toilet?
Do you still have old flapper? If so, take it with you and match it up for a better fit one. Just a suggestion.
jmon is offline   Reply With Quote
Old 01-11-2016, 09:40 PM   #3
Rewards Points: 2,038
If it's a toto toilet you need a TOTO flapper.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (01-13-2016)
Old 01-12-2016, 07:27 AM   #4
Rewards Points: 101
I'll have to check the brand when I get home. I'm pretty sure it wasnt TOTO. As for the size. A 2" flapper didn't fit so I went looking at Home Depot and the only larger flapper I could find was the 3".
Old 01-13-2016, 04:22 PM   #5
Rewards Points: 101
Its an American Standard Toilet. Looking at the old flapper it looks like it has a rubber gasket on the underside that may be designed to be replaced rather than the whole flapper. Below are some pictures of the old flapper itself and the new flapper in the toilet. If you look close you can see my "fix" for the new flapper by using some foam by the left hook that hols the flapper onto the the overlow tube post. The foam keeps it from slidding over off center. Even if it works for now, id rather find a proper solution. My water bill went from $40-50 to 106. Does this sort of setup look familiar to anyone? Do I just buy a rubber gasket to properly fix it? What brand is it? Is it american standard or some other brand?
3" Toilet flapper keeps leaking-img_3859.jpg   3" Toilet flapper keeps leaking-img_3860.jpg   3" Toilet flapper keeps leaking-img_3861.jpg   3" Toilet flapper keeps leaking-img_3862.jpg
Old 01-13-2016, 05:17 PM   #6
Rewards Points: 101
Just answered most of my questions from my last post. Flipped over the tank kid and found a diagram with part numbers. It has the flapper assembly part 738920-0070A. Looks like I can get the flapper online for about $6 or it looks like the rubber seal from after market manufacturers for about $2.
Old 01-14-2016, 10:56 AM   #7
Rewards Points: 323
Was there slack in the chain
ct18 is offline   Reply With Quote
Old 01-14-2016, 11:38 AM   #8
Rewards Points: 101
There was a little slack. The lever arm was kind of short pulling the flapper to the left. The safest repair looks to be to just get the original model flapper which I can get from Home Depot ship to store for $8. I'll probably try to replace the lever arm to one that is long enough to pull up rather than off to the side.
Old eljer toilet with flush ball (no flapper) leaks cbrc5eric Plumbing 18 04-24-2014 01:51 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Strangely Leaking Toilet... OhmZoned Plumbing 4 01-14-2012 11:55 AM
Sterling toilet, flapper issues dinosaur1 Plumbing 13 06-19-2011 07:25 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
