3" Toilet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2012, 09:09 PM   #1
3" Toilet Drain
I have a 3" toilet drain from the 2nd floor, draining straight down in a 2x6 wall below and into the basement, connecting to a horizontal 3" main line. I was told this could siphon the water out of the toilet because it drops more than 36". Is this true? If so, what can be done to solve the problem? Possibly offset the 3" pipe in the wall below with some 45 degree eldows?
KShirriff is offline   Reply With Quote
Old 11-07-2012, 09:15 PM   #2
Old 11-07-2012, 09:16 PM   #3
the 2" pipe to the top left is a vent
Old 11-07-2012, 09:17 PM   #4
Old 11-07-2012, 09:18 PM   #5
Rewards Points: 12,818
Is that pipe that runs straight up from the Y a vent line going through the roof?
Old 11-07-2012, 09:18 PM   #6
this is an idea of what I thought might solve the problem. Anyone have some input?
Old 11-07-2012, 09:19 PM   #7
no that connects to the bottom of the toilet.
Old 11-07-2012, 10:02 PM   #8
DIY staff
Rewards Points: 7,174
Where did you hear such a thing? If it is vented properly you have no siphoning----
A licensed plumber will be along soon----I never heard of that---
Old 11-07-2012, 10:21 PM   #9
Someone who claims to know plumbing. It is vented with a 2" vent coming out the left side with a Y. This goes up through the roof. Does this look right? Or should I offset the drain to keep it from being a straight drop to the basement?
Old 11-07-2012, 10:58 PM   #10
Rewards Points: 352
you should be fine the toilet flushes by siphon action then refills the bowl while the tank refills.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
KShirriff (11-08-2012)
Old 11-08-2012, 12:09 AM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 348
I've done a handfull of toilets like that when there was no other way- people get freaked out when something is unconventional. Should work fine, the only thing I don't like is the flat 2" vent- my inspectors tend to frown on them when they're below the fixture like that. It would be better if it was at a continuous 45* rise.
The Following User Says Thank You to TheEplumber For This Useful Post:
Tags
toilet drain rough-in
1.5" vent for toilet with 3" drain? fulmar2 Plumbing 24 11-04-2012 11:06 AM
Left obstruction in toilet drain... help! mikemcd Plumbing 5 10-17-2012 05:32 PM
Upstairs Toilet Drain wab Plumbing 13 06-14-2011 12:15 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Plumber's Question..about Toilet drain K.M.G Plumbing 4 09-23-2009 03:06 PM
